It is currently Thu Feb 09, 2012 5:44 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 34 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject:
PostPosted: Tue Mar 04, 2008 11:25 pm
Pro Handyman
Has thanked: 18 times
Been thanked: 26 times
:thumbright:
Jaeger.
darrenc wrote:
I dont think its a stupid question but does show a lack of understanding of how paint works and reasons for certain applications, now dont jump down my throat Jaegar i'm not being funny its just a classic case in point of a well educated professionally trained painter against a general tradesman.
 Post subject:
PostPosted: Wed Mar 05, 2008 8:34 am
Has thanked: 109 times
Been thanked: 406 times
Hoovie wrote:
I did indeed - though issue may be too strong a word for it.
the sanding disc is secured by a grub screw tighted by an allan key and it undid itself - and getting it back in there to retighten was a right PITA - once done, it was fine again .............
have you no room for a star washer or spring washer!!! :scratch:
http://www.screwfix.com/prods/93917/Bol ... RS-_-93917
 Post subject:
PostPosted: Wed Mar 05, 2008 8:59 am
Borders Bodger
Been thanked: 1 times
a good suggestion, but it is a grub screw with no head, so a washer would just drop off
 Post subject:
PostPosted: Wed Mar 05, 2008 9:14 am
l o l a very tecnical term "just drop off " :thumbright: :thumbright:
is there any exposed thread to fit a lock nut!!!
 Post subject:
PostPosted: Wed Mar 05, 2008 9:32 am
Borders Bodger
problem is, the grub screw has to be tightened with the disk in situ, and the hole that the allan key goes through is tiny - only slightly larger then the allan key itself - so only an grub screw will work probably.
The locking works by the screw pushing down through the disc into the rotating central spindle, not going into a locating hole in the spindle (I will check it there is a locating hole I have missed, though :lol: ) so it is solely down to pressure.
If I found a replacement screw with some sort of head, it would have to be really spot on, as if the thread was slightly too long, washer wouldn't bite, if it were slightly too short, it wouldn't hit the central spindle and hence not secure - and it is not possible to look behind the disc with it in place as the shroud around the disk is part of the cast.
I guess it is one of these design things that the screw works loose and needs refitting periodically. Unfortunately, it is not possible to add a 'tightening' policy periodically as it is not possible to see the grub screw when it is fitted (but I have had a thought how to deal with that :thumbright: )
Maybe I should do a video of "Refitted the sanding disc on a Rexon Bench Sander" :wink:
 Post subject:
PostPosted: Wed Mar 05, 2008 11:43 am
Clear nail varnish might hold it in place "H", :wink:
I still have'nt used the compressor i won, but when the weather improves( :roll: ) i'll be using it a lot,shed to build, decking to make, wishing well to make (i've a long list) :lol: , then i'll do a review. :thumbright: No camcorder though :oops: , so no video. :cb :lol:
People forget how fast you did a job - but they remember how well you did it.
I no longer skinny dip, i chunky dunk these day's.
 Post subject:
PostPosted: Wed Mar 05, 2008 11:50 am
Has thanked: 2 times
Been thanked: 45 times
And what are you doing having clear nail varnish in your tool box, need to touch up your nails sweetie??
:lol: :lol: :lol: :lol:
John
 Post subject:
PostPosted: Wed Mar 05, 2008 11:51 am
Borders Bodger
only got cherry red colour :lol:
 Post subject:
PostPosted: Wed Mar 05, 2008 11:56 am
I use black it matches the underside of the fingernails :lol:
John
 Post subject:
PostPosted: Wed Mar 05, 2008 12:17 pm
It's in my old fishing tackle box :thumbright: i used it when re-whipping rod rings. :lol:
 Post subject:
PostPosted: Wed Mar 05, 2008 12:26 pm
I hope my wife doesn't read this forum, she supports the Toon, if she ever finds out I talk to someone from Sunderland I'll be divorced.
Wait a minute I'll email her the link! :lol: :lol: :lol: :lol: :toothy7:
John
 Post subject:
PostPosted: Wed Mar 05, 2008 1:29 pm
"Toon" :wtf: Give me her e-mail address. :cussing: ::b :angryfire: :boxing: :lol: :lol: :lol:
 Post subject:
PostPosted: Wed Mar 05, 2008 1:50 pm
Aye, and she comes from Hull, married a Cornishman 'cos the English weren't good enough.
One daughter born in Portsmouth (Pompey) one in Plymouth (Guzz). Quite a mix.
I support Cornwall Rugby Team, can't be bothered with these 'Nancy' footballers!
Oh and the English and Rugby team, except if Wales or Scotland win, then I'm a Celt!!
I also support English football teams playing abroad gives an excuse for a beer.
John
 Post subject:
PostPosted: Wed Mar 05, 2008 2:38 pm
Borders Bodger
don't worry lads, there will still be the Sunderland-Newcastle derby game next year :thumbright:
not sure in which league, though :lol: :lol:
 Post subject:
PostPosted: Wed Mar 05, 2008 7:47 pm
Has thanked: 5 times
Been thanked: 86 times
Some type of grubscrews are more prone to coming undone than others. Flat bottom ones dont tighten up as well as cup point or cone point.
You can get knurled cup point ones aswell, they rarely work loose. :wink:
