It is currently Fri May 25, 2012 5:10 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 9 posts ]
PostPosted: Tue Sep 20, 2011 11:19 pm
Been thanked: 3 times
hey folks
i scored a free trailer :thumbright:
yes there is a reason it was free... but :idea1:
i am going to remove the old rotten ply and restore the metal frame...
i have the power drill and a SDS drill... the frame is got plenty of surface rust and the paint... what's left of it! is in shite
would a metal brisle type attachment do the job of cleaning up the frame? would the metal brisle get it to a point where its ready for paint/spray? or would i be best to bring it to the local sand blaster fella and not metal brisle it?
i bought a welder and am a raw novice.... hopefully the welds to come will hold!
anyway any advies on how best to start getting thre trailer ready for paint/spray would be great :)
o yea on the spray/paint side of the project... what about a tin of metal paint?
PostPosted: Wed Sep 21, 2011 12:58 am
Has thanked: 6 times
Been thanked: 108 times
Brushes in drills are pretty poor.
A Twist knot cup brush in an angle grinder works much better. If you are willing to pay to have it blasted, get that done. Will get into the corners easier, plus you wont need to do it yourself. :thumbleft:
Once its blasted, it will need painting asap, before any rust starts forming again.
From the blasting, no other prep is required except a blow over with an airline to remove any dust.
Get yourself practicing the welding, is it one of theses cheap Lidl affairs?
Take a look here-
http://www.mig-welding.co.uk/arc-tutorial.htm
Theres no point me telling you about it, its all there....should get you going.
PostPosted: Wed Sep 21, 2011 12:35 pm
tis a arko welder 185 s
http://eshop.svarovani.cz/svarovani-tec ... mator.html
yup gona do(try) a wee bit of welding on the trailer and then bring it to the sand blaster
thanks for the advise :thumbright:
PostPosted: Wed Sep 21, 2011 6:12 pm
Get it blasted first, then you will have clean metal to weld.... :thumbright:
PostPosted: Wed Sep 21, 2011 9:36 pm
good thinking batman! well i tried my first weld there disevenin.... jaysis! brutal.... but its holding so thats a good thing :)
but hopefully il get the trailer blasted in the next week :thumbleft:
PostPosted: Mon Sep 26, 2011 11:02 pm
ok so picked up trailer from sand blaster :thumbright: i will try to figure out how to post pics some day :oops:
the blaster fella says i really should put on under coat first.... any advise on what under coat to use??
PostPosted: Tue Sep 27, 2011 9:42 am
Been thanked: 69 times
Red oxide... assuming zink paint would be too expensive for you.
Mike
PostPosted: Tue Sep 27, 2011 11:14 am
Red oxide... super thanks mikew :)
PostPosted: Thu Sep 29, 2011 6:16 pm
Red oxide is a half decent general purpose paint.
If you plan on using hammerite, watch what primer you use. I have had problems with reactions between the two.
Zinc phosphate would be better, but more expensive.
Or an epoxy based primer would be even better....
