It is currently Tue Apr 23, 2019 1:36 am
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
 Post subject: Re: Replacing sockets
PostPosted: Fri Sep 07, 2018 8:24 pm
Has thanked: 41 times
Been thanked: 1470 times
Yes, they are not all exactly the same size
PostPosted: Fri Sep 07, 2018 8:25 pm
Has thanked: 30 times
Been thanked: 3 times
Annoying! What's the best way to tidy up? Caulk? I don't want to glue the socket lol
Sent from my SM-G930F using Tapatalk
PostPosted: Fri Sep 07, 2018 8:54 pm
Depends on what is there.
Take the socket off (again :roll: ) and "flatten" the wall
For this message the author someone-else has received gratitude : mole81
PostPosted: Fri Sep 07, 2018 9:21 pm
Has thanked: 86 times
Been thanked: 58 times
They are not identical, but all the front-plates extend well beyond the back-box. So its only usually a problem if whoever did the decorating or plastering didn't go in towards the back box far enough - or if the old one was screwed up to still-wet paint, so that it pulled the paint off. Sadly these short-cuts are fairly common.
In some cases the socket can be tweaked slightly in position to best cover defects, before fully tightening. That could be worth a try before getting into premature redecorating.
Kev
PostPosted: Fri Sep 07, 2018 9:23 pm
Thanks, I've only just decorated, guess I should of removed the sockets to check first!
PostPosted: Sat Sep 08, 2018 7:42 am
Has thanked: 45 times
Been thanked: 750 times
If things are really bad you can also fit socket plates behind, some don't like them but I am not too fussy about them and they are cheap and easy to fit, no need to remove the wires.
PostPosted: Sat Sep 08, 2018 9:27 am
Approved Electrician
Has thanked: 175 times
Been thanked: 594 times
OchAye wrote:
someone-else wrote:
mole81 wrote:
where can I buy a tiny length of earth cable and sleeve?
Any good DIY store.
B&Q Washington (Tyne and Wear) did not have earth sleeve. Balls to that ... but easy enough to get 100m from toolstation WTF.
You are not short of electrical wholesalers in Washington :-)
Three of the big national companies are on the same industrial estate. ISTR CEF, Neways and YESSS are next to each other.
PostPosted: Sat Sep 08, 2018 9:42 am
Save starting a new thread, what is the standard depth of a double socket pattress? I bought a mk one to replace and aged existing with ml plate that is 32mm the unit it is replacing is only 20mm is this normal?
PostPosted: Sat Sep 08, 2018 10:47 am
Pattresses (and back boxes) are available in different depths, so there is no one standard. It gives flexibility for different depths of electrical unit and different amounts of cabling behind them. You can usually go bigger/deeper than necessary, its just a case of aesthetics or perhaps vulnerability if it sticks out from the wall further. Which is good because they aren't so popular these days, and choice is more limited: ~30mm is most common, with a deeper one for cooker switches etc and a slimmer one for light switches.
Unlike metal back-boxes, pattresses are typically made to fit the size and shape of the socket quite closely, including the radius at the corners. So for a seamless finish it is best to replace the pattress as well as the socket if you're changing brand, which it sounds like you are doing..
Kev
PostPosted: Sat Sep 08, 2018 10:49 am
OK that's clear, I have bought the same brand socket and pattress though the new pattress is 12mm deeper than the one it's replacing and can't seem to find a shallower one in the mk brand
PostPosted: Sat Sep 08, 2018 11:19 am
Yeah, I was editing my post as you responded. Pattresses aren't so popular these days, and so IMO choice is more limited: ~30mm is standard/common for MK sockets, there are deeper ones but I don't think they do a slimmer one for double sockets, the next one down is about half the depth (for light switches). Personally I think they look fine (for a surface mounted box) and its not good to cramp the wiring too much, so perhaps its a fair compromise.
There are differences between brands though, some may go for 25mm/1" instead for instance, if you particularly need it to be lower profile.
Kev
