Page 1 of 1
[ 3 posts ] |
| Author |
Message |
HandyGeoff
Posted: Tue Nov 15, 2011 4:42 pm |
| Newly registered Member |
Joined: Sat Mar 12, 2011 3:11 pm Posts: 73 Has thanked: 0 times Been thanked: 2 times
The ballcock in the supply tank in the loft has been dripping and causes the tank to overflow. It's thick will limescale too so I bought a new valve and float to replace it.
Access to the tank is severely restricted and I can't get my head in to see what I'm doing. I can reach over and managed to remove the pin and float arm. With an adjustable spanner I have located the nut on the valve and turned it many times but it doesn't seem to be coming off.
Should I be gripping something else as I turn the nut on the valve? Or should I be unscrewing the nut on the outside of the tank instead?
| Top |
gib_goblin
Posted: Tue Nov 15, 2011 5:38 pm |
| Senior Member |
Joined: Thu May 24, 2007 11:51 am Posts: 560 Location: Wiltshire Has thanked: 3 times Been thanked: 6 times
Just so happens I recently had to complete the exact same job in our loft.
You'll need to unscrew the nut on the outside of the tank which joins to the mains - should be fibre washer in the nut - if you can't remove the washer in one peice you'll need a replacement to fitt the new ballcock.
Next you undo the nut on the outside of the tank, this compresses the ballcock fitting into the plastic wall....when I refitted the new ballcock a few turns of PTFE tape on the thread made for a good watertight seal.
_________________ Don't buy a dwarf with learning difficulties,
It's not big and it's not clever.
| Top |
register or
log in
HandyGeoff
Posted: Tue Nov 15, 2011 5:44 pm |
OK, sorted thanks. I did try to remove that nut initially but it wouldn't budge so thought I'd better check.
| Top |
register or
log in
Page 1 of 1
[ 3 posts ] |
