It is currently Mon Mar 25, 2019 8:05 am
PostPosted: Thu May 31, 2018 9:20 pm
Has thanked: 1 times
I need to remove and replace a Honeywell 2 port valve. The problem is it is fitted into the copper pipe run by compression fittings.
How do I remove the valve please?
PostPosted: Thu May 31, 2018 9:30 pm
Has thanked: 840 times
Been thanked: 941 times
Obviously drain the water enough to not have any in the pipe work it is fixed to, then undo the compression nuts, pull them up the pipe then pull the pipes out from the compression body.
Sometimes you have to undo a further connection if there is no room for movement in the pipe work, but hopefully you can get an inch or so movement to enable the pipe to be pulled back enough.
To fit new one reverse the instructions.
I always put jointing compound around the olives before assembling.
If you replace with another Honeywell valve you shouldn’t have to remove the old olives and nuts.
Dave
www.drlgas.co.uk
PostPosted: Thu May 31, 2018 10:08 pm
Many thanks, Dave. The problem is the valve is in a pipe run with little or no wiggle room. How do I get yhe pipe out of yhe compression joints if there is no leeway?
PostPosted: Thu May 31, 2018 11:05 pm
Has thanked: 84 times
Been thanked: 78 times
If you are absolutely certain that there are no other connections in the pipe run, or there is no give or spring in the pipe run to enable you to remove the valve, then you could consider the following option.
Cut the pipe, fit new valve, replace the cut pipe with existing nut and olive, and fit one of these.
https://www.wickes.co.uk/Wickes-Solder- ... m/p/195177
Hopefully Dave will approve.
For this message the author PLB has received gratitude : Omagh
PostPosted: Thu May 31, 2018 11:31 pm
Many thanks. Will certainly give it a go!
PostPosted: Fri Jun 01, 2018 6:12 am
Has thanked: 323 times
Been thanked: 969 times
Not bad PLB but judging by the OPs skill level I'd go for something like this :wink:
http://www.plumbers-mate-sales.co.uk/22 ... 2121-p.asp
For this message the author Razor has received thanks - 2: gas4you, PLB
PostPosted: Fri Jun 01, 2018 8:37 am
Thanks Razor.
I have never seen a slip compression coupling!
Dave
www.drlgas.co.uk
PostPosted: Fri Jun 01, 2018 10:38 am
gas4you wrote:
Thanks Razor.
Thanks, I didn't know they did one either. !
PostPosted: Fri Jun 01, 2018 1:53 pm
If I need one I usually just file the stop out of a standard one :thumbright:
PostPosted: Tue Jun 19, 2018 6:48 pm
Try changing just the motor first. Much more common for them to fail than the actaul valve.
No drain down required!
Sent from my LG-H930 using Tapatalk
