It is currently Mon Jul 16, 2018 7:32 pm
PostPosted: Fri Jun 09, 2017 7:01 pm
Has thanked: 3 times
I'd made a previous post here (http://www.ultimatehandyman.co.uk/forum1/replace-drayton-rts1-with-honeywell-cm927-t89582.html) but decided to change my mind on what I'm doing so thought a new post was appropriate.
I've decided to replace my Drayton LP241 heating/hot water controller with a Hive 2 Heating/Hot Water controller.
I have looked at the wiring of the current controller and it seems the same as the Hive 2 one, though their wiring diagram is a bit uninformative (http://www.alswebpage.net/wp-content/uploads/2015/12/Hive-Connections.png - Dual channel one)
I've attached the images of the timer back plate and wiring. Can anyone please let me know if I need to change the wiring at all when I replace the controller with the Hive one? 1 and 2 on the wiring diagram aren't used at all at present, only L, N 3 & 4.
We also have a Drayton RTS1 at the moment as our thermostat (that's awful and needs to go). How would I go about safely disconnecting/decommissioning that?
PostPosted: Sat Jun 10, 2017 7:29 am
Has thanked: 422 times
Been thanked: 3903 times
You got a lot of extra wires in there that need identifying first, I'm away till Monday, hopefully Dave will look in and advise.
For this message the author thescruff has received gratitude : eddiebove
PostPosted: Sat Jun 10, 2017 7:54 am
Thanks for the reply. I think some of the extra wires may be because we have a solar hot water system. However, this isn't controlled by the Drayton LP241 so that might not be it.
The boiler is an Ideal Icos HE24 if that helps!
Users browsing this forum: PLB and 2 guests
