Page 1 of 1
[ 11 posts ] |
| Author |
Message |
dan007
Posted: Tue Sep 20, 2011 9:02 pm |
| Newly registered Member |
Joined: Sat Dec 06, 2008 3:44 pm Posts: 12 Has thanked: 0 times Been thanked: 1 times
hi been plastering and rendering a few years lately having a problem with render blowing cracking and sometimes top coat appears weak ie easily marked when ladders leant against them i always soak walls first with water use washed plastering sand 4 sand 1 cement use addmixture everbuild 3 in 1 premium waterproofer plasticiser to slow down setting time then soak the scratch coat then apply top coat with 5 sand 1 cement again with add mix as above then float wall and sponge granted last job was on relatively hot day and sun was on wall all afternoon please advise
| Top |
All The Gear
Posted: Thu Sep 29, 2011 8:19 pm |
Joined: Mon Mar 29, 2010 9:26 am Posts: 87 Has thanked: 0 times Been thanked: 7 times
Are you not using any lime, mate?
| Top |
register or
log in
dan007
Posted: Sun Oct 02, 2011 2:59 pm |
no just the 3in 1 admix plasticiser waterproofer & retarder
| Top |
register or
log in
All The Gear
Posted: Sun Oct 02, 2011 9:29 pm |
I usually go 4:1:1 sand, cement, lime for the scratch and 5:1:1/2 sand, cement, lime for the topper.
| Top |
register or
log in
dan007
Posted: Mon Oct 10, 2011 7:44 pm |
many thanks is that hydrated lime
| Top |
register or
log in
cwplastering
Posted: Mon Oct 10, 2011 7:49 pm |
| Senior Member |
Joined: Thu Jul 09, 2009 7:01 pm Posts: 1777 Location: Peterborough Has thanked: 44 times Been thanked: 114 times
probably... have you been down the particle accelerator at cern by any chance?
| Top |
register or
log in
cwplastering
Posted: Mon Oct 10, 2011 7:54 pm |
| Senior Member |
i use a 3 or 4:1 with waterproofer scratch no need for lime in scratch... then a 6:1:1 or 8:1:1 float coat... long as the float coat is weaker than the scratch your fine... wont be sandy... leave it a good week between scratch and float coat...
use waterproofer in scratch.... maybe a tiny bit in float coat in summer but not this time of year, the lime does the plasticising...
| Top |
register or
log in
dan007
Posted: Sun Oct 16, 2011 3:27 pm |
many thanks is it hydrated lime i need
| Top |
register or
log in
Dave59
Posted: Wed Oct 26, 2011 12:20 am |
Joined: Wed Oct 26, 2011 12:10 am Posts: 2 Has thanked: 0 times Been thanked: 1 times
Get a plasterer in! Rendering is a a tricky thing to do if you dont know what you are doin. It is not a handyman job, because handymen dont really know what they are doing. They are a jack of all trades, not a master of one.
| Top |
register or
log in
Rich-Ando
Posted: Wed Oct 26, 2011 12:50 am |
| Pro Sparky |
Joined: Sat Mar 24, 2007 12:24 pm Posts: 6033 Location: Spondon, Derby Has thanked: 85 times Been thanked: 193 times
that's not what this forum is about really dave59. as your 1st post you could be a little more helpful to the poster.
| Top |
register or
log in
Dave59
Posted: Fri Oct 28, 2011 12:16 am |
Ok. Rendering on a hot day is not advised. I always use a plasticiser/waterproofer/retarder in both coats. You can use an sbr bond which will hold back the suction rate. Apply this before the scratch coat and the final coat. Water it down to 3:1.
| Top |
register or
log in
Page 1 of 1
[ 11 posts ] |
