It is currently Fri May 25, 2012 4:49 pm
PostPosted: Wed Apr 13, 2011 10:58 am
Has thanked: 10 times
Hi guys,
i have an external wall approx 2m by 1m covered in old pebbledash render which is knackered & will be taken off
if i was to apply a coat of sand & cement would this be good protection against the weather (rain especialy)?
also do i need to add anything to the mix? & do i need to seal the wall with pva or similar beforehand?
PostPosted: Wed Apr 13, 2011 10:04 pm
Has thanked: 1 times
Been thanked: 12 times
hack off spray down wall scratch coat 4:1 plastering sand and cement with waterproofer. lay it on rule it off and run a scratch combe through it makeing sure not to dig it in right down to the bricks as this will ruin the bond.
top coat of 5:1 plastering sand and cement some people use waterproofer in the top coat and some dnt, i do but i dnt think its 100% needed but as i said i do just to be safe, lay it on rule it off fill in hollows rule off till its all flat and true, let it pick up a bit then float it up with a polyurethane float and finish with a sponge, always rub float and sponge in smooth circular motions. some others might be along to offer different ways of doin things to give you some options
PostPosted: Thu Apr 14, 2011 12:38 pm
cheers for the info
is the waterproofer needed or can i get away without it as its such a small area?
PostPosted: Thu Apr 14, 2011 3:45 pm
its best to put the waterproofer in mate other wise it wnt last in the weather and could give you more problems
PostPosted: Thu Apr 14, 2011 8:17 pm
why is the skim applied in two layers & not one?
PostPosted: Thu Apr 14, 2011 9:57 pm
makes sure you get a good bond also the bricks can grin through if you do one coat makes it easier to get a nice true wall first coat only takes out so much discrepantcies and the top coat flattens off lovley.
also i dnt know how deep you have to fill but if you put it on too thick it can sag and crack
