| Author |
Message |
TheApprentice2011
Posted: Thu Jan 26, 2012 4:59 pm |
| Senior Member |
Joined: Tue Jan 04, 2011 2:59 am Posts: 308 Has thanked: 19 times Been thanked: 3 times
I have snapped on of the bolts that hold the earth/negative return to the body in the engine bay on my mk1 ford focus, it was one of those moments when you then think I know what I should have done, put some wd40 on:oops:, anyway do you think I should just drill it out and re tap it or use one of these extractor sets, I have just bought a tap and die set from aldi. If you think I should give one of these extractors ago can you recomend one. Thanks in advance
| Top |
Cannyfixit
Posted: Thu Jan 26, 2012 5:30 pm |
| Senior Member |
Joined: Sat Dec 15, 2007 7:55 pm Posts: 1236 Location: Cheshire Has thanked: 21 times Been thanked: 58 times
does it just bolt the earth wire to the body,if thats the case just drill another hole and new nut and bolt or self tapper would be my surgestion
_________________ If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here :
http://www.donnasdreamhouse.co.uk/#/please-donate/4529684719
| Top |
register or
log in
kellys_eye
Posted: Thu Jan 26, 2012 5:33 pm |
| Senior Member |
Joined: Mon Mar 15, 2010 11:49 pm Posts: 2316 Location: Oban Has thanked: 62 times Been thanked: 217 times
As above - don't make more work than is required. Drll a new hole in CLEAN metal (remove all paint from vicinity to ensure good connection) and use a nut/bolt if you can get to the rear to hold the nut. Unless the metal is faily thick (i.e. good for at least 1/4" of thread length) then simple tapping won't last long.
_________________ This post may contain nuts
| Top |
register or
log in
TheApprentice2011
Posted: Thu Jan 26, 2012 5:43 pm |
| Senior Member |
It's above the wheel arch sort of thing so don't know how thick it is. hard to explain if you havn't seen a mk1 focus, I'll try and get pic tommorow. The funny thing is that was the reason I was trying to remove the bolts canny to try and clean the area up,
| Top |
register or
log in
Cannyfixit
Posted: Thu Jan 26, 2012 7:07 pm |
| Senior Member |
I have a Mk1 focus post me a picture if you can and i'll have a look tomorrow
| Top |
register or
log in
Hitch
Posted: Thu Jan 26, 2012 8:35 pm |
| Senior Member |
Joined: Mon Jan 16, 2006 8:16 pm Posts: 4674 Location: Somerset Has thanked: 6 times Been thanked: 108 times
Id go with a new hole/bolt, it doesn't matter much where it goes. If its a bolt, its probably into a rivnut, or welded insert. A large self tapper may do, what size is the bolt?
_________________ Why isn't the number 11 pronounced onety one?
| Top |
register or
log in
btcc
Posted: Sat Jan 28, 2012 10:27 pm |
| Newly registered Member |
Joined: Sat Jan 29, 2011 4:34 pm Posts: 94 Has thanked: 6 times Been thanked: 5 times
| Top |
register or
log in
register or
log in
Cannyfixit
Posted: Mon Jan 30, 2012 4:37 pm |
| Senior Member |
Just had a look and it's under the air box so just remove the other bolt next to and fit the earth ring to that one,obviously take a little care add a lttle WD40 and let it soak in for a while otherwise you'll snap that one to
| Top |
register or
log in
TheApprentice2011
Posted: Mon Jan 30, 2012 4:45 pm |
| Senior Member |
Whats under the airbox, the pic is next to the washer bottle opening, which is the white thing in the pic.
| Top |
register or
log in
Cannyfixit
Posted: Mon Jan 30, 2012 4:50 pm |
| Senior Member |
the black box to the left is the airbox
| Top |
register or
log in
TheApprentice2011
Posted: Mon Jan 30, 2012 5:03 pm |
| Senior Member |
yeah, but u said under, anyway do you not think it's worth a shot with the extractor set or not thick enought to retap as if if i just move it ove the slot for the tab will be wrong way
| Top |
register or
log in
Cannyfixit
Posted: Mon Jan 30, 2012 5:15 pm |
| Senior Member |
Sorry for the wording It's up to you with the extractor set,personally i wouldnt but thats just me,as for moving the wire over all's your looking for is a good earth,the tab just holds the ring tag in place when tighting down, either snip it off or fold it back flat with some pliers just make sure you clean the area before refitting if you decide to drill it out post back how you get on
| Top |
register or
log in
TheApprentice2011
Posted: Mon Jan 30, 2012 5:31 pm |
| Senior Member |
How thick do you think this area is as kellys said unless 1/4" it won't last, anyway will pick up an extractor set either tommorow or wednesday as I've got to get some other bits anyway
| Top |
register or
log in
Cannyfixit
Posted: Mon Jan 30, 2012 6:37 pm |
| Senior Member |
1/4" is not the body thickness that Kellys talking about but the minimum bolt length,without looking i'd gusss most car body panels to be about 1-2 mm thick.
| Top |
register or
log in
