It is currently Thu Jun 21, 2018 6:48 pm
Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2, 3  Next
PostPosted: Thu Oct 05, 2017 6:22 pm
Has thanked: 177 times
Been thanked: 26 times
Removed the glass of the borrowed lights just need to board and replaster.
Is it just as easy as studding the inside out at the correct depth then screwing a sheet of plasterboard either side, taping the joints and plastering? Image
Sent from my SM-G950F using Tapatalk
PostPosted: Thu Oct 05, 2017 6:31 pm
Has thanked: 1444 times
Been thanked: 3690 times
pretty much. obvs. it'll need a mist coat before repainting.
For this message the author wine~o has received gratitude : kevinsmbuk
PostPosted: Thu Oct 05, 2017 8:29 pm
Sure, will mist coat. Just kept reading more complicated versions online saying it will crack? Can't think why
PostPosted: Thu Oct 05, 2017 8:47 pm
Has thanked: 377 times
Been thanked: 1370 times
Possibly they're talking about the top part of the borrowed light frame being flush with the finished plaster unless it's cut back to stud level.
For this message the author ayjay has received gratitude : kevinsmbuk
PostPosted: Thu Oct 05, 2017 9:50 pm
You mean that the wooden frame will sit flush with the plasterboard and therefore be plastered over? Hmm.. Yeah I guess just taping and plastering over that is a no no?
If not the whats the best way of cutting it back?
PostPosted: Thu Oct 05, 2017 9:52 pm
Also can I just fill the void at the top with bonding and plaster over?
PostPosted: Thu Oct 05, 2017 10:44 pm
Has thanked: 988 times
Been thanked: 1833 times
You need to cut the top portion of the door frame out. Then make a little timber frame around the opening you are left with and plasterboard.
If the the current door frame is 95mm wide or 120mm wide(these are standard sizes) then you want to use 70mm or 95mm wide framing if you plan to plasterboard tape and fill. If you are planning on scrimming and skimming with plaster then use cls timber which is approximately 5mm narrower which will allow for a skim coat on the plasterboarding.
For this message the author steviejoiner74 has received gratitude : kevinsmbuk
PostPosted: Fri Oct 06, 2017 11:15 am
Cheers Steve, couple of questions, I am a bit of a novice with wood. Would you build the frame then insert in the space or build inside the space? Where would you fix the frame to?
I measured the width of the door framing and it come out at 90mm! :?
PostPosted: Fri Oct 06, 2017 5:44 pm
Has thanked: 48 times
Been thanked: 497 times
do you mean you want the part above the door flush with the wall ?
Stud frame - plasterboard 2-3mm under the level of the wall and skim, you can plasterboard under the edge of the box/frame and use a corner bead to give you a nice bottom edge
if you want it seamless finish take back the plaster either side and remove the bead so you can lose the edge
For this message the author Bob225 has received gratitude : kevinsmbuk
PostPosted: Fri Oct 06, 2017 9:13 pm
Do you mean literally remove the plaster to the right and left of the window frame and tin snip the bead out?
PostPosted: Fri Oct 06, 2017 9:14 pm
Yes I want the part above the door as if it wasn't there
PostPosted: Sat Oct 07, 2017 8:19 am
Has thanked: 42 times
Been thanked: 640 times
I know they are a bit old fashioned but I quite like the fact we have them in our flat.
PostPosted: Sat Oct 07, 2017 3:38 pm
In a word yes, the finished effect would be a door inset into a wall, simple enough job - try not to over think it
you could even extend the frame out and have a architrave around the opening giving the door a deep inset look
PostPosted: Sat Oct 07, 2017 6:19 pm
Just out of curiosity what's to stop me using a router to take back the door framing back by 12.5mm + 3mm each side then just plasterboard over that?
PostPosted: Sat Oct 07, 2017 7:44 pm
sorry I need to get my eyes checked :? I didn't enlarge the pic, it looked like it was inset but its just where the arc was doh :tool: :roll: :roll: :roll:
throw in a few noggins, router the frame back, plasterboard over skim to finish, its a small area so a bit of 9.5mm PB will do the trick
