It is currently Wed Jan 17, 2018 1:23 pm
Visit Thermo worx
Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sun Oct 08, 2017 10:34 am
Has thanked: 166 times
Been thanked: 23 times
Door frame width is 87/88mm I got 63mm width timber thinking it was 95mm oops! Image
Sent from my SM-G950F using Tapatalk
PostPosted: Sun Oct 08, 2017 10:59 am
Has thanked: 945 times
Been thanked: 1752 times
2 skins of plasterboard without plaster will be fine then. The top architrave/facing will cover the join between door frame and plasterboard. Just fill the drywallscrew holes with easifil and sand. Bit of scrim/papertape on the vertical joints and easifill and sand.
For this message the author steviejoiner74 has received gratitude : kevinsmbuk
PostPosted: Sun Oct 08, 2017 11:43 am
Ok great cheers. I suppose another option is to get some 9.5mm board then it leaves me with just under 3mm each side for skim.
Quick question with the ceiling batton it's being fixed to plasterboard. Is it just a case of using strong plasterboard fixings if I can't fix to a joist? ?
PostPosted: Sun Oct 08, 2017 12:14 pm
if You make a little frame up that’s a nice snug fit then if it’s vertically fixed well to each wall then that’ll be fine if you can’t get a fixing into a ceiling joist.
And yes using 9mm plasterboard will allow for a skim coat if you want to plaster.
PostPosted: Sun Oct 08, 2017 12:32 pm
It's brick either side and crumbling plaster on right wall in that pic. very difficult to get a good fixing, but used an sds 8mm plugs and long screws. It isn't moving
PostPosted: Sun Oct 08, 2017 12:45 pm
Can't even get a fixing into these they are hollowImage
PostPosted: Sun Oct 08, 2017 12:58 pm
Frame up Image
PostPosted: Sun Oct 08, 2017 3:26 pm
One side done Image
PostPosted: Sun Oct 08, 2017 4:07 pm
Done. Just to check the bits of mortar that are missing to the side of the pb I was planing on using bonding to fill is that ok? Image
PostPosted: Sun Oct 08, 2017 10:34 pm
Jack Of All Trades
Has thanked: 187 times
Been thanked: 257 times
I have to ask what cost £1.50?... :lol:
By eck! ©
PostPosted: Sun Oct 08, 2017 10:53 pm
Squirt a bit expanding foam in the gaps and they’ll cover no bother with some scrim and plaster.
PostPosted: Mon Oct 09, 2017 1:36 pm
lol the plasterboard was reduced in Wickes as it was damaged, but as I only needed sections of the sheet it didnt matter to me
PostPosted: Mon Oct 09, 2017 1:37 pm
I've already chucked some bonding in there now, will scrim that and plaster
PostPosted: Mon Oct 09, 2017 3:28 pm
Has thanked: 38 times
Been thanked: 399 times
you branch of wickes is tight, ours let you stick a donation in the charity box if its under £5
PostPosted: Mon Oct 09, 2017 7:26 pm
Sort of, I bought some £13 secateurs too, I didn't realise until after the chap had discounted them to 1.50 and charged me full price for the plasterboard lol result!
Would be happier to contibute towards charity instead if they done that!
Users browsing this forum: OchAye and 2 guests
