It is currently Wed Feb 21, 2018 1:16 am
Visit Thermo worx
PostPosted: Mon Jul 24, 2017 5:35 pm
Has thanked: 1 times
Been thanked: 1 times
I install wood burning stoves. I've got a job coming up and they're insisting it has to be completed on the day. Issue is I've got to render a fireplace opening. It's a very large hole and won't be very close to the stove for this reason, so the heat isn't a big issue. But what is an issue is I usually do these type of jobs over two days. Day one opening up the hole, fitting hearth, liner etc and applying scratch coat.. Day 2 plastering wall and applying final coat of render, putting stove in to position.
But.. I've got a problem with th scratch coat situation. Do I just use one coat directly on to the bricks, or is there another option? Could I use rapid set cement for the scratch coat? Is it possible to render directly on to hardiebacker? If so I could line the fireplace with that and render.
Thank You!
PostPosted: Mon Jul 24, 2017 5:48 pm
Has thanked: 170 times
Been thanked: 101 times
Could you explain to them that by doing it in 1 day you could compromise the finish and possibly create future issues?
PostPosted: Mon Jul 24, 2017 8:17 pm
I've explained. What i said is that I'll have to do it in one coat and it'll be likely to crack as it'll dry too quickly. Still they're insistent that any crack is less of a problem than me taking more than a day. Though they know it'll crack, I'd still prefer to do all I can to prevent it happening! :-)
PostPosted: Mon Jul 24, 2017 10:25 pm
They sound like the kind of customer I'd avoid. You know whose fault it'll be when it does crack.
Sorry I can't help with your problem though.
Why will they only allow 1 day?
PostPosted: Mon Jul 24, 2017 10:47 pm
They're going on a 90 day cruise. I had no availability except on the day before they leave. They want it ready to use when they return. I wasn't fussed about doing the job so worked out my quote and added £700 on top so they would go with someone else.. But they didn't. As with anything like this I'll get in writing their acceptance that there could be cracks in the render. I'm just hoping someone can tell me if rapid set would be suitable as a scratch, because that's what I'm going to try if I don't hear it's a problem.
PostPosted: Sat Jul 29, 2017 7:45 pm
Has thanked: 236 times
Been thanked: 1091 times
you should know, rapid set cant be used as a scratch coat.
lime based render/plaster or for a quick instant job fire board.
For this message the author cotswold builders has received gratitude : Joshy88
PostPosted: Wed Aug 02, 2017 5:55 pm
Thanks a lot Cotswold. When you say fireboard, are talking vermiculite board, hardiebacker or something else like supalux? Are these okay to render?
