It is currently Fri Mar 23, 2018 10:50 am
Visit Thermo worx
PostPosted: Thu Nov 04, 2010 10:36 pm
Hi all,
I've just moved into a brand new house and had a look up in the loft to see about laying a few of the usual B&Q/Wickes tongue and groove loft flooring. It's a 3 storey house with the top bedroom built into the roof (as with many new builds), so I wasn't expecting much room.
On inspection there are loads of joists spanning the middle of the loft floor to the ceiling, which looks to limit what I'll be able to do. Even if all the floor was boarded it'd still be difficult to get around.
Anyway I was expecting the joists to stick up between the insulation so the boards could be screwed on top and sandwich the insualtion between boards. Problem is they're not. All I see is an unbroken sea of insulation.
I presume excessive sqaushing of insulation is not the way to go but how do I go about raising the joists so I can put the boards over. I've only been able to poke my head up through the hatch so far as I can't see were to stand.
If you haven't gussed, I'm new to this lark.
Thanks for any info.
PostPosted: Fri Nov 05, 2010 7:16 am
Has thanked: 12 times
Been thanked: 32 times
You can raise the joists by screwing (never nail in a loft as you crack the ceiling plaster underneath) joists to the existing joists.
Compressing the loft insulation should be avoided as this means that it is not as effective.
