It is currently Fri May 25, 2012 4:21 pm
PostPosted: Mon Nov 07, 2011 7:54 am
Has thanked: 3 times
Does anyone know why the following may be happening?
If I select my "water heating" timer to come on (not the central heating)
all my radiators seem to give off heat at the same time my water is getting heated!
Is this something that should be happening? as it just seems a bit odd to me that
the radiators get warm when I have not set the central heating on.
Any help would be appreciated.
PostPosted: Mon Nov 07, 2011 8:15 am
OAP
Has thanked: 187 times
Been thanked: 2114 times
Possibly a faulty diverter.
Some information about the boiler etc would help.
PostPosted: Mon Nov 07, 2011 1:26 pm
Thanks for replying.
I will have a look tonight and post up some more details.
PostPosted: Mon Nov 07, 2011 9:39 pm
I have taken a couple of shots of the setup inside my airing cupboard, below.
Overview of airing cupboard
Blue part - Valve?
There was also the frontage of an old part I found disgarded
on the floor of the airing cupboard, which looks like the blue
part has been replaced before, see below;
Red part - pump?
I am guessing that this part is the pump?
PostPosted: Mon Nov 07, 2011 10:40 pm
Has thanked: 57 times
Been thanked: 99 times
Thanks for posting the pics
Nice high point there above the pump,bet great system to re fill
It sounds as though the 3 port valve body is faulty ,requires replacing (valve with the blue head),it seems to be letting by to the heating pipework when it should be positioned to isolate flow to rads or it could be seized in mid position
If you have found help on the UHM's forums,why not help out the UHM's Nominated Charity,find out more here
PostPosted: Tue Nov 08, 2011 8:02 am
Thanks for the info.
I will have a look tonight and see when the water heating comes on whether the lever moves up
to the "W" position or if it is stuck on the "M" position.
Users browsing this forum: No registered users and 8 guests
