It is currently Fri May 25, 2012 4:20 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 12 posts ]
PostPosted: Sat Oct 29, 2011 3:54 pm
Hi fellow members,
Tried to be a diy hero today, which thought I had cracked, but now having doubts!
The thermostat on an upstairs radiator broke sometime ago and so the plunger was fully open, making the room like an oven. I could not find a replacement thermostat, so i decided to replace the whole value.
Having taken advice via the internet, I drained the system via a downstairs radiator. I then went to work to replace the value on the upstairs radiator. Naturally, a lot of water came out of the radiator, but replaced the value with no problems.
I have turned the heating back on, but now none of the heaters are warming up and the combi-boiler pressure is over 2. I have mistakenly let too much air into the boiler via the filling loop - but I do not how to reduce the pressure. I have tried bleeding some of the other radiators, but it has made no difference to the pressure.
I would appreciate any help.
Many thanks.
PD
PostPosted: Sat Oct 29, 2011 4:14 pm
OAP
Has thanked: 187 times
Been thanked: 2114 times
Have you bled the boiler and pump.
PostPosted: Sat Oct 29, 2011 4:44 pm
Hi 'thescruff',
No I have not. How would I do that?
PostPosted: Sat Oct 29, 2011 4:47 pm
OAP
Best to check in the manual, you should find one in the manuals forum if you don't have copy, otherwise one of the boys should put you right if you post the details.
PostPosted: Sat Oct 29, 2011 4:49 pm
Has thanked: 57 times
Been thanked: 99 times
Is the hot water side working ?
Have you vented all the radiators to let all air out ?
If you have found help on the UHM's forums,why not help out the UHM's Nominated Charity,find out more here
PostPosted: Sat Oct 29, 2011 5:20 pm
Hi White Pan Man,
Hot water side is working. Do I need to vent all the radiators?
PostPosted: Sat Oct 29, 2011 5:33 pm
I have now vented all the radiators. It seems there is very little water in the system. How do I replenish this?
PostPosted: Sat Oct 29, 2011 5:36 pm
My combi-boiler is Alpha HE CB25..
PostPosted: Sat Oct 29, 2011 5:46 pm
Has thanked: 166 times
Been thanked: 613 times
keep bleeding your radiators and topping up the pressure at the boiler...
PostPosted: Sat Oct 29, 2011 5:48 pm
Turn off the boiler and top up the system presure as you did with the filling loop ,when you filled to 2 bar,fill to 1.5 bar and then vent rads again,when presure drops refill untill all rads vented then,fill to 1.5 bar and turn boiler on,hopefully will run ok
PostPosted: Sat Oct 29, 2011 7:44 pm
I have bleed the radiators, pressure was at 1.5. Turned boiler on, it's now 2 and the radiators are not warming up - how quick should I expect them to start getting hot?
PostPosted: Sat Oct 29, 2011 10:29 pm
OAP
Is the boiler lighting in the heating mode.
Have you checked and bled the pump.
alpha-he-cb-25-installation-manual-t40748.html
Users browsing this forum: No registered users and 8 guests
