It is currently Fri May 25, 2012 4:19 pm
 Post subject: Radiator Help Please.
PostPosted: Wed Nov 02, 2011 5:32 pm
Has thanked: 2 times
What size square drive do I need to remove the top plug from my radiator, also could you tell me please what size allen key I need to install the male part of the lockshield valve? Also I have just fitted a new radiator in another room but the TRV that I bought to go with it doesnt have a taper fitting radiator side of the connection. Is there some knack to get these to seal without using copius ammounts of thread tape? I Put it together with tape and hylomar but I am going to have to remove it again because there is a very slight weep from this area.
Cheers,
Stu.
PostPosted: Wed Nov 02, 2011 5:41 pm
OAP
Has thanked: 187 times
Been thanked: 2114 times
The tail should be 12mm, the plug at the top is normally a spanner, but you could try the 12mm.
To seal the threads get a small tube of Loctite 55 string and follow the instructions.
For this message the author thescruff has received gratitude : stoobydale
PostPosted: Thu Nov 03, 2011 8:31 am
Thanks for the reply Scruff. Another thing that I forgot to ask, in the pack woth the radiator there was some little white plastic clips. What am I supposed to do with these as I can't see anywhere to fit them?
PostPosted: Thu Nov 03, 2011 8:34 am
Has thanked: 76 times
Been thanked: 373 times
They go on the brackets where the rad hangs and stop it vibrating. Also pretty useful if one side is a mill low :wink:
For this message the author Razor has received gratitude : stoobydale
PostPosted: Thu Nov 03, 2011 8:35 am
Ahh, thanks for that. Easy when you know how eh?
Users browsing this forum: No registered users and 8 guests
