It is currently Thu Feb 09, 2012 8:31 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 13 posts ]
PostPosted: Mon Aug 02, 2010 9:36 am
Has thanked: 1 times
Hi there,
Hope you can help.
I have a vertical radiator weighing around 60kg to be fixed to a plaster board wall. The wall is a cavity wall with the brick being 12cm behind the plaster board. Any ideas how to fix this raduator securely to the wall?
Many thanks in advance.
Jaxonian
PostPosted: Mon Aug 02, 2010 10:02 am
Has thanked: 33 times
Been thanked: 174 times
Hi Jaxonian,
Infortunately, you need grounds behind the plaster board, normally the dot and dabbers will allow a panel of adhesive behind the plasterboard to allow for fixing thro' into the brick work. You might be able to drill thro' and get a good fixing in the brickwork and then not tighten the rad brackets too much so that the plasterboard is not pulled in.
S
Measure twice, cut once!
PostPosted: Mon Aug 02, 2010 10:09 am
Has thanked: 151 times
Been thanked: 509 times
Hollow wall anchors
http://www.screwfix.com/search.do;jsess ... utton.y=10
PostPosted: Mon Aug 02, 2010 10:22 am
Unfortunately the wall isn't dry lined there's a cavity of about 12cm between the plaster board and the solid wall.
Will hollow wall anchor's take 60kg of weight do you think?
I'm worried the plasterboard won't support the weight of the radiator. the weight will be spread over 4 fixings though.
It's been suggested I need noggings which would involve taking a big chunk of plaster board out to fix them and replacing it.
What do you think?
PostPosted: Mon Aug 02, 2010 10:33 am
Personally, I would cut out 2 horizontal sections of plasterboard and fix strips of say 12mm MDF to the wall and then replace the plasterboard and redec.
S
PostPosted: Mon Aug 02, 2010 11:02 am
OAP
Has thanked: 181 times
Been thanked: 1983 times
What you do is drill a hole through the plasterboard, and insert a sleeve, say 15mm copper, that touches the wall behind and finishes flush with the PB.
Drill a hole through the sleeve into the wall behind and push a wall plug in, using a long enough screw, fix the bracket to the wall, you get a strong fixing and the sleeve stos the board pulling in.
PostPosted: Mon Aug 02, 2010 11:20 am
Been thanked: 32 times
One hell of a long screw that is at 12" plus :?
Sciatica is a pain in the Ar5e ............ and leg
PostPosted: Mon Aug 02, 2010 11:28 am
I think the OP meant 12mm
S
PostPosted: Mon Aug 02, 2010 11:29 am
OAP
Either dot and dab and 12cm is a mistake, dry lined with timber, or someones stood a sheet of PB against the wall.
PostPosted: Mon Aug 02, 2010 12:05 pm
This is the cavity wall, it's an external wall. the gap shown by the pencil is 12cm wide and i've just cut a big hole in it so I can fix some wood that will take up the gap.
Any ideas?
File comment: hole in wall - fix a 60kg radiator to this if you dare!
PostPosted: Mon Aug 02, 2010 1:40 pm
Has thanked: 13 times
Been thanked: 36 times
What I did when fitting a new heavy radiator, was to cut two slots in the wall which were the size of the radiator brackets. Then insert a length of wood edge on and screw this to blockwork behind, then screw the bracket to the wood. They are solid.
However, I only had a 65mm gap to fill between blockwork and front of plasterboard.
Here's a pic showing a batten. This one has a notche cut out so that it bridges over the two pipes I found when cutting the hole :)
HTH
J
File comment: Radiator mounting on batten
I am not a pro.
PostPosted: Mon Aug 02, 2010 7:08 pm
OAP
If it's a steel framing, you can fix a sheet of ply between the uprights and screw the PB back on, or use ply the same thickness as the PB.
PostPosted: Tue Aug 03, 2010 9:18 pm
thanks for all your suggestions guys. i've fixed wooden battens to the brickwork and then screwed rad brackets to them through the ply. it seems solid enough although yet to test as i'm now struggling with a plumbing issue! and this is why i love DIY??/? ::b
Users browsing this forum: darrenba and 4 guests
cron
