Page 1 of 1
[ 15 posts ] |
| Author |
Message |
caricature
Posted: Thu Apr 28, 2011 12:12 pm |
| Senior Member |
Joined: Fri Jan 21, 2011 11:01 am Posts: 303 Has thanked: 12 times Been thanked: 3 times
If its been asked before apologises,I have ordered or should say bought off of E-bay some extra R.A.M checked the compatibility and it all looks ok,the thing is and I perhaps should have found out before,how will the computer recognize it, will I need to install a programme to get it to run with the new ram. Thanks in advance.
| Top |
Inky Pete
Posted: Thu Apr 28, 2011 12:22 pm |
| Senior Member |
Joined: Fri Feb 03, 2006 2:34 pm Posts: 1206 Location: Cheshire Has thanked: 6 times Been thanked: 85 times
Your PC should "discover" the new memory for itself when it boots up after you install it.
(provided it's compatible, and is the right size)
What machine have you got, how much memory have you currently got, and what have you bought?
| Top |
register or
log in
BillyGoat
Posted: Thu Apr 28, 2011 12:23 pm |
| Troll Headbutter |
Joined: Sat Jan 01, 2011 8:20 pm Posts: 1889 Has thanked: 77 times Been thanked: 130 times
It's easy....
1. Computer off 2. Remove power cable (and battery if a laptop) 3. Hold power button to discharge any remaining power 4. Fit new RAM 5. Connect power 6. Enjoy
The computer should reconise the memory and then boot into Windows (assuming you are usign windows) which will just use the new memory.
To check it's detected alreet...... click start > RIGHT click on Computer > Properties and see memory there :)
Cheers
(remember componants are not happy with static - be sure to take precautions when handling. Don't do it on a carpet, wearing a wooly jumper, etc, etc...)
| Top |
register or
log in
caricature
Posted: Thu Apr 28, 2011 12:31 pm |
| Senior Member |
Thanks to the both of you.You've put her mind at rest,thats an achievment. Pete its a Dell dimension 3100 whatever that means, currently it as 512 ram have bought 1gb. Billy,you make it sound easy,I hope I don't prove you wrong,thanks again.
| Top |
register or
log in
register or
log in
caricature
Posted: Thu Apr 28, 2011 12:46 pm |
| Senior Member |
I shall return and let you know,once again thanks.
| Top |
register or
log in
register or
log in
kellys_eye
Posted: Thu Apr 28, 2011 1:27 pm |
| Senior Member |
Joined: Mon Mar 15, 2010 11:49 pm Posts: 2316 Location: Oban Has thanked: 62 times Been thanked: 217 times
Do NOT remove the power cable. Leave it connected but switched OFF at the wall socket. The earthing of the casing is essential to prevent damage caused by static discharge which can destroy your memory chip quite easily.
_________________ This post may contain nuts
| Top |
register or
log in
tooltraderdirect
Posted: Thu Apr 28, 2011 1:54 pm |
| Newly registered Member |
Joined: Mon Sep 13, 2010 11:45 am Posts: 55 Has thanked: 2 times Been thanked: 1 times
kellys_eye wrote: Do NOT remove the power cable. Leave it connected but switched OFF at the wall socket. The earthing of the casing is essential to prevent damage caused by static discharge which can destroy your memory chip quite easily. That's a useful tip. Never tried that myself, but I use an anti-static wrist-strap. I always unplug as I regard the cost of RAM quite cheap when my life is at stake but switching off at the wall solves that little issue
| Top |
register or
log in
cje001
Posted: Thu Apr 28, 2011 2:25 pm |
| Senior Member |
Joined: Fri Apr 08, 2011 8:35 pm Posts: 110 Has thanked: 0 times Been thanked: 1 times
The above has been noted! I didnt know that before!
| Top |
register or
log in
dave.m
Posted: Fri Apr 29, 2011 1:37 pm |
| Senior Member |
Joined: Tue Jun 09, 2009 5:30 pm Posts: 5071 Location: A Yorky in Lancashire Has thanked: 16 times Been thanked: 339 times
Kelly's advice about leaving the plug in but switched off is fine AS LONG AS the cable is plugged into a switched socket.
Do NOT leave it plugged in if the socket does not have a switch on it.
dave
_________________ You can always tell a Yorkshireman,
But you cannot tell him much.
| Top |
register or
log in
BillyGoat
Posted: Fri Apr 29, 2011 4:14 pm |
| Troll Headbutter |
I remember that practise being abandoned in a well known chain of stores after the earth carrying stray voltage that was suspected of causing damage. I know it's not normal as such, but always a possibility....
| Top |
register or
log in
kellys_eye
Posted: Fri Apr 29, 2011 7:49 pm |
| Senior Member |
Quote: ....but I use an anti-static wrist-strap. which is the ideal way to do it but not accessible to most people. Also, keep fingers away from the 'gold teeth' at the edge of the device. Leave it in it's protective package until you are going to fit it. Ensure it is the right way around when fitting (it has keyed slots to ensure this is so) and make doubly sure you push it firmly home (giggidy) and the tabs at the ends of the socket 'click' to the upright position.
| Top |
register or
log in
caricature
Posted: Sat May 07, 2011 11:15 am |
| Senior Member |
Many thanks to all,they came this morning and following the instructions from above fitted and working a treat.
| Top |
register or
log in
register or
log in
Page 1 of 1
[ 15 posts ] |
