It is currently Fri May 24, 2013 12:25 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 1 post ]
PostPosted: Thu Feb 16, 2012 10:37 am
Has thanked: 12 times
I have a stone resin 900mm x 900mm tray to install on to a concrete floor. The floor is level and I've dug out the hole for the waste trap.
What method can I employ to secure the tray to the floor? It is going into a corner (brick walls) and will be ceramic tiles to the other 2 floor sides.
I am contemplating the use of silica sealant around the base lip to seal it to the floor as once the floor tiles are fitted the tray should have no lateral movement. A fair amount of silica sealant will also be applied to the 2 edges where contact with the walls will exist.
Is all this adequate or should/do I need adopt a different approach?
