It is currently Fri Feb 22, 2019 12:15 am
PostPosted: Sun May 11, 2014 3:51 pm
Has thanked: 5 times
Been thanked: 2 times
hi guys !
i need your help
got problem with my push bike
never been repairing my bike before so dont know what is going on:)
i bet you will know straight away:)
anyway.my pedal fell off and i picked it up and manage to get home with just one :)
im trying to put it back .i think i have all bits : pedal itself screw and little black cover
but i cant push pedal onto little squere tube to the real end.i do have a gap and it worring me
and make me think if i lost maybe something on the way back home.
please look at the photos and let me know what you think.
i tried to robber mallet knock it to the end but little sqere tube is getting thicker as you go closer to the bike.
please let me know if you reckon you can help me
KIND REGARDS
PostPosted: Sun May 11, 2014 4:05 pm
Been thanked: 7 times
Hi, there is meant to be a gap there, just make sure the bolt is done up nice and tight. If it keeps working loose you could try some threadloick on the bolt
PostPosted: Sun May 11, 2014 5:11 pm
Has thanked: 643 times
Been thanked: 1816 times
The spindle (axle) is usually tapered so that the pedal arm (crank) gets pulled on tight by the bolt. As EE says the gap on the spindle is quite normal.
Painting with BIN
PostPosted: Sun May 11, 2014 5:26 pm
Has thanked: 143 times
Been thanked: 53 times
If you have the nut that goes on the end of the tapered bit, just do that up tight and put the cover back on. As long as theres no play in the pedal arm once tightened then its done.
PostPosted: Sun May 11, 2014 6:59 pm
thanks a lot guys
a lot appreciate it
i have done like you said
and im ready to still useing my bike again.
just posted to double check
lovely stuff.
its done nice and tight !
cheers again guys !
you are legends !
PostPosted: Mon May 12, 2014 8:33 pm
diesel demon
Has thanked: 172 times
Been thanked: 176 times
I had a problem with the left one on my bike, went ar$e over t1t avoiding crashing into a small person who ran out in front of me, knocked the pedal which then fell off complete with crank after a few miles, could not get the damn thing to stay on for more than a couple of miles at a time no matter how tight I made it. tried locktite, drilling & tapping the crank to add a grub screw, all to no avail, ended up replacing the crank & it's been fine since
i love being married
I have a soft spot for the wife, it's a peat bog just outside Ardross
Still Yes Highland
PostPosted: Mon May 12, 2014 8:44 pm
Has thanked: 1531 times
Been thanked: 3852 times
Pfffft......whatever happened to "Cotter pins" ???
PostPosted: Tue May 13, 2014 12:05 am
Has thanked: 18 times
Been thanked: 109 times
Had a similar problem on a bike not worth spending much on and welded a washer to the crank which held the pedal on.
That did the trick.
Mike
