Page 1 of 1
[ 13 posts ] |
| Author |
Message |
Posted: Sat Jul 04, 2009 9:53 am |
| Pro Carpenter |
Joined: Sat Dec 16, 2006 10:11 pm Posts: 10522 Location: redhill surrey an auld reekie laddie Has thanked: 134 times Been thanked: 473 times
its years since i "proofed" a stainless steel frying pan
i have a thick based prestige stainless steel pan and it does a fantastick job at advertising sticks like sh1t regardless what action i take
any ideas please the pan is new and has never worked properly
_________________ we are all ------------------still learning
| Top |
rio.
Posted: Sat Jul 04, 2009 2:22 pm |
| Senior Member |
Joined: Fri Nov 14, 2008 4:47 pm Posts: 1051 Location: surrey Has thanked: 0 times Been thanked: 5 times
the process is known as "seasoning" in the trade.
clicky
| Top |
register or
log in
Posted: Sat Jul 04, 2009 2:42 pm |
| Pro Carpenter |
excelent
i tried all combinations off oil salt and water and got nowhere
do you let it boil dry!!
| Top |
register or
log in
rio.
Posted: Sat Jul 04, 2009 4:27 pm |
| Senior Member |
you guess is as good as mine, i only found the link using the term "seasoning"
i would try filling the pan 3/4's full of the solution, and then boil it until its reduced to an 1/8'S full, anymore and it may tarnish the pan?
the instructions are not that clear
| Top |
register or
log in
Posted: Sat Jul 04, 2009 8:34 pm |
| Pro Carpenter |
ok cheers
| Top |
register or
log in
Bludall
Posted: Sat Jul 04, 2009 9:19 pm |
| Forum Chatterbox |
Joined: Wed Apr 11, 2007 10:19 pm Posts: 10527 Has thanked: 3 times Been thanked: 0 times
_________________ If at first you don't succeed, ask UHM in your hour of need!
| Top |
register or
log in
Posted: Sat Jul 04, 2009 10:29 pm |
| Pro Carpenter |
would certainly work on cast iron as they are tough as old boots
not shure about stainless steel though
| Top |
register or
log in
thescruff
Posted: Sat Jul 04, 2009 10:35 pm |
| OAP |
Joined: Mon Mar 10, 2008 12:46 am Posts: 39986 Has thanked: 187 times Been thanked: 2114 times
For stainless steel you want a cup full of vinegar and water, then bring it to the boil, for a few minutes.
_________________ If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here : donnas-dream-house-charity-t52110.html
| Top |
register or
log in
Posted: Sat Jul 04, 2009 10:47 pm |
| Pro Carpenter |
excelent scruff thats the second vote for vinegar
| Top |
register or
log in
Stoday
Posted: Sun Jul 05, 2009 2:49 am |
| Deceased 21-10-2011 R.I.P |
Joined: Fri Jan 20, 2006 6:03 pm Posts: 5956 Location: East of England Has thanked: 9 times Been thanked: 93 times
I've never done it the way suggested so far.
I put a hazelnut sized amount of lard in the pan and heat. Let it run all over the bottom of the pan and keep heating until it starts to smoke. Keep it going a little longer whilst the fat turns yellow, pour off and allow the film to cool.
Never wash the pan, just wipe it with a paper towel.
You do not want a non-stick finish — you can buy that cheaply. You should be aiming for a finish that will hold a pancake whilst you tilt the pan. It's impossible to cook a good thin pancake in a non-stick pan or a sticky pan either. You need it to hold whilst you tilt and turn the pan so the pancake gets a swirling pattern on its outside.
_________________ I should be dead; I've cheated the Grim Reaper yet again by surviving my third heart attack in June.
| Top |
register or
log in
rio.
Posted: Sun Jul 05, 2009 8:58 am |
| Senior Member |
you could try potato peelings if the vinegar method is no good.
clicky
| Top |
register or
log in
Posted: Sun Jul 05, 2009 11:28 pm |
| Pro Carpenter |
thanks stods a reo
to be honest its years since i peeled a potato as a lot off the taste texture and vitimins are just under the skin
| Top |
register or
log in
tsmessi
Posted: Tue Aug 04, 2009 9:14 am |
| Newly registered Member |
Joined: Tue Aug 04, 2009 9:13 am Posts: 1 Has thanked: 0 times Been thanked: 0 times
| Top |
register or
log in
Page 1 of 1
[ 13 posts ] |
