-> Rogues Gallery |
| Author |
Message |
ultimatehandyman Site Admin
Joined: 16 Jul 2005 Posts: 9287 Location: Darwen, Lancashire
Posted: Tue Feb 05, 2008 8:47 am Post subject: Professionally fitted basin |
This basin is in a downstairs cloak room, It was fitted by a professional plumber.
The plumber seems to think that he can make water flow along a level pipe, that is approximately 10 feet long and has two ninety degree bends
As you can see from the above picture the waste pipe is almost level with the floor, it then bends ninety degrees before connecting to another piece of waste pipe that is about 8 feet long, this piece was also level
I have cut about two inches from the chrome pipe and lifted the waste pipe so that there is now a decent fall on the waste pipe.
Hopefully the sink will actually empty now, rather then the water just sitting there for days/weeks. _________________ DIY | DIY Video |
| Back to top |
handyman Senior Member
Joined: 16 Jan 2006 Posts: 2673 Location: Alderley Edge, Cheshire
Posted: Tue Feb 05, 2008 8:49 am Post subject: |
nice wallpaper  _________________ Go on, adopt a greyhound http://www.dgrescue.org.uk/ ..........................................................................  |
| Back to top |
Telmay Senior Member
Joined: 09 Mar 2007 Posts: 2402 Location: Worthing, West Sussex
Posted: Tue Feb 05, 2008 9:06 am Post subject: |
| Back to top |
bathstyle BATHROOM DESIGN AND INSTALLATION
Posted: Tue Feb 05, 2008 1:53 pm Post subject: |
| That's not a proper seal joining onto the chrome, he should have used a standard multifit elbow, let's hope the pipe never blocks, it's all very well having pipe work that doesn't leak when in use, but to have pipe work that is truly water tight is the way it should be done |
| Back to top |
simpleplumb Senior Member
Posted: Tue Feb 05, 2008 4:12 pm Post subject: |
one of my better jobs  |
| Back to top |
Posted: Tue Feb 05, 2008 4:36 pm Post subject: |
| bathstyle wrote: |
The chrome pipe just fits inside of the plastic and was not sealed at all, but it had some flakes of plastic on the outside, as if someone had tried using pvc cement or something.
The sink has leaked badly in the past and thw whole floor has been soaked.
I siliconed the chrome pipe into the plastic as a temporary measure, but will try and find the correct joint. I will be removing the joints again when I box it all in. _________________ DIY | DIY Video |
| Back to top |
BobProperty plumbing and property
Posted: Tue Feb 05, 2008 5:12 pm Post subject: |
| bathstyle wrote: |
Those chrome pipes are a pain. What product exactly do you suggest, because when I tried a compression fitting the chrome pipe was too small. (maybe I shouldn't use cheap screwfix ones, I know) You can see that on this installation. The chrome pipe is on the inside of a street elbow if I'm right. _________________ Treat everyone like they are a rich distant relative, in whose will you'd like to be remembered. |
| Back to top |
Posted: Tue Feb 05, 2008 5:24 pm Post subject: |
| BobProperty wrote: |
| bathstyle wrote: |
Those chrome pipes are a pain. What product exactly do you suggest, because when I tried a compression fitting the chrome pipe was too small. (maybe I shouldn't use cheap screwfix ones, I know) You can see that on this installation. The chrome pipe is on the inside of a street elbow if I'm right. |
Yes it is just pushed inside.
Not sure what would be the best, but I was thinking of pushing the pipe in and then using one of these- http://www.screwfix.com/prods/29220/Plumbing/Uni-Compression-Waste/Flexi-Waste-Straight-Coupling-30-38mm _________________ DIY | DIY Video |
| Back to top |
Tryanything Senior Member
Posted: Sat Feb 09, 2008 3:20 am Post subject: |
Might be an idea to get rid of that monstrosity of an abortion and bye something that looks nice  _________________ SILVER---------HOG |
| Back to top |
Posted: Sat Feb 09, 2008 10:41 am Post subject: |
| Tryanything wrote: |
Might be an idea to get rid of that monstrosity of an abortion and bye something that looks nice  |
You know what women are like- it was a real bargain, apparently  _________________ DIY | DIY Video |
| Back to top |
Posted: Wed Feb 13, 2008 10:12 pm Post subject: |
Just like the handbag I bet  |
| Back to top |
Hoovie Devon DIYer
Posted: Wed Feb 13, 2008 10:19 pm Post subject: |
| Telmay wrote: |
I wonder if there is another basin in another room - painted pink that has a rope across the door so people can look but not touch
Women ! can't live with 'em and not allowed to shoot 'em  _________________ If you have a son, DO NOT name him after a verb ....
"Which is it, man?" |
| Back to top |
Cannyfixit Senior Member
Posted: Wed Feb 13, 2008 10:39 pm Post subject: |
I think its a nice contemporary feature just hope the rest of the decor is being done  _________________ Gary |
| Back to top |
Posted: Wed Feb 13, 2008 10:43 pm Post subject: |
Pity that Hoovie - the shooting bit  |
| Back to top |
Posted: Fri Feb 15, 2008 12:02 am Post subject: |
| Telmay wrote: |
Couldn't agree more  _________________ SILVER---------HOG |
| Back to top |
