Ultimate Handyman Home
possible gas leak or just really bad boiler???
Post new topic   Reply to topic   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum -> Central Heating & Boilers
Andrew
PostPosted: Sat Oct 04, 2008 8:22 am    Post subject: possible gas leak or just really bad boiler??? Add User to Ignore List Reply with quote
I haven't been using my boiler at all for the last two months (at all, not once, except for the blue flame showing at the front of the boiler).
Still, over two months i've managed to use 20 units of gas.
Should I be worried? I know my boiler is absolutely ancient (Vaillant VCW Sine 18 T3) so could it just be that on the way out?
Please advise - i'm getting a little worried now!
Thanks.
Back to top
thescruff
PostPosted: Sat Oct 04, 2008 8:30 am    Post subject: Add User to Ignore List Reply with quote
It's surprising how much the pilot will actually burn.
What are the units, ft or m
Scruff
Back to top
Andrew
PostPosted: Sat Oct 04, 2008 9:38 am    Post subject: Add User to Ignore List Reply with quote
m3.
Back to top
D Hailsham
Member
PostPosted: Sat Oct 04, 2008 12:58 pm    Post subject: Add User to Ignore List Reply with quote
A pilot light reduces the Sedbuk rating of a boiler by four percent.
Back to top
thescruff
PostPosted: Sat Oct 04, 2008 1:07 pm    Post subject: Add User to Ignore List Reply with quote
That's a lot of gas (220kw) ish, but no an impossible amount, I always turn the pilot off through the summer for that reason.
Perhaps it's time to consider a new boiler.
Scruff
Back to top
Andrew
PostPosted: Sat Oct 04, 2008 1:43 pm    Post subject: Add User to Ignore List Reply with quote
but if i turned the pilot out, wouldn't that mean i couldn't get hot water on demand (even though this is hypothetical, as i haven't been using the boiler at all throughout the summer, not for hot water or heating)?
New boiler? Perhaps. Damn!
Thanks.
Back to top
thescruff
PostPosted: Sat Oct 04, 2008 2:11 pm    Post subject: Add User to Ignore List Reply with quote
Yes, you could turn the pilot off during long shutdowns, and obviously you need it for hot water or heating.
As for the new boiler, you need to consider the cost saving of the fuel x capital outlay.
Example, new boiler £1500.00, gas saving £200.00 year.
As you can see the savings of a new boiler is not good from a financial position, to get the maximum benefit it should only be a consideration if the existing boiler breaks down and or becomes unreliable.
Scruff
Back to top
Display posts from previous:
Post new topic   Reply to topic    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum -> Central Heating & Boilers All times are GMT
Page 1 of 1
