Ultimate Handyman Home
porch roof
Goto page 1, 2  Next
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Building Forum
consquires
Junior Member
PostPosted: Sat Jun 21, 2008 8:52 am    Post subject: porch roof Add User to Ignore List Reply with quote
I am building a lean to porch but need help with roof. anyone have any drawings for sloped roof
Back to top
joiner_uk
PostPosted: Mon Jun 23, 2008 9:43 pm    Post subject: Add User to Ignore List Reply with quote
I dont have a specific drawing for your porch as I do not know what you want.
What do you need to know?
Carpenter & Joiner Sheffield
Back to top
consquires
Junior Member
PostPosted: Tue Jun 24, 2008 4:14 pm    Post subject: Add User to Ignore List Reply with quote
here is photo of porch so far. need to know how roof timbers are fitted
 Description:
 Filesize:  131.23 KB
 Viewed:  612 Time(s)
Back to top
PostPosted: Tue Jun 24, 2008 7:47 pm    Post subject: Add User to Ignore List Reply with quote
You might get some ideas here-
http://www.ultimatehandyman.co.uk/forum1/5ft-x-6ft-porch-roof-t4269.html
http://www.ultimatehandyman.co.uk/forum1/door-and-window-canopy-help-t620.html
DIY | DIY Video
Back to top
Hoovie
Devon DIYer
PostPosted: Tue Jun 24, 2008 8:33 pm    Post subject: Add User to Ignore List Reply with quote
There is also a post here with photos with a Pitched roof being erected
http://www.ultimatehandyman.co.uk/forum1/rain-stopped-play-t5699.html and somewhere on site some diagrams for it
Back to top
joiner_uk
PostPosted: Wed Jun 25, 2008 8:58 am    Post subject: Add User to Ignore List Reply with quote
The wall plate you have (the 4"x2") may want to be lifted up slightly so the rafter when fixed is 10mm or so above the block work. The wall plate should be bedded on level with cement.
Fix the 6" x 1" bearer to the wall. Make sure this is level.
Then cut your rafter with the plumb cut at the top, the birds mouth but leave the bottom of the rafter longer (this will be cut back when the rafter is fixed). Once you are happy with your rafter use this as a template for the others. You will probably only have about 6 rafters in total.
Now all the rafters are fitted cut back the rafters for your eaves. Try to match the main roof depth for your soffit.
Post up the pictures of your progress Thumbright
 Description:
Lean to roof
 Filesize:  13.13 KB
 Viewed:  581 Time(s)
Back to top
consquires
Junior Member
PostPosted: Thu Jun 26, 2008 8:10 pm    Post subject: Add User to Ignore List Reply with quote
will certainly do as you suggest.how do you suggest the wall plate is raised?. am working away from home for about a week, so will let you know how I get on, when I get back.
Back to top
joiner_uk
PostPosted: Fri Jun 27, 2008 10:27 pm    Post subject: Add User to Ignore List Reply with quote
You could raise the wall plate by bedding it on with cement.
This may only need doing if your using more than 4x2 for rafters
Back to top
consquires
Junior Member
PostPosted: Tue Jul 08, 2008 10:29 am    Post subject: Add User to Ignore List Reply with quote
have managed to start rafters for roof during short break in rain.
I am thinking I will need rafters at outside walls. Plan to place rafter on wall plate and bolt to out side wall. does this sound right?
Back to top
consquires
Junior Member
PostPosted: Tue Jul 08, 2008 10:35 am    Post subject: Add User to Ignore List Reply with quote
photo of progress so far
 Description:
 Filesize:  56.56 KB
 Viewed:  500 Time(s)
Back to top
joiner_uk
PostPosted: Wed Jul 09, 2008 6:32 pm    Post subject: Add User to Ignore List Reply with quote
Looking good Thumbright
How are the finishing the verges with barge board or rendering up to the undercloaking?
I would not put a rafter on the outside wall just cut a short length with the birds mouth on then set inside the first block. You will then be able to finish the corner with a block cut down for rendering. Fix 2 noggins across to support the rafter, fix the top noggin as high up as you can probably on top of wall pate so only 2" high or so.
Measure out from the block work to the end of the rafter to mark your soffit depth say 200mm. Remeber the render will add 25mm.
Mark the end rafters and draw plumb lines then string line across on top of the rafters. Draw you plumb line down from the marks on the rest of your rafters. Take care when cutting back the rafters as this can go wibbly wobbly when the fascia is fitted. Fix some brackets to hold the soffit in place use plywood or 4x1
 Description:
 Filesize:  4.02 KB
 Viewed:  473 Time(s)
Back to top
consquires
Junior Member
PostPosted: Fri Jul 11, 2008 6:23 pm    Post subject: porch roof Add User to Ignore List Reply with quote
How are the finishing the verges with barge board or rendering up to the undercloaking? scratch
Not really sure what you mean, could really do with a drawing of what you suggest. Instead of putting rafter on outside wall
I really am playing this 1 by ear.
Thanks for your help so far
Back to top
skiking
PostPosted: Fri Jul 11, 2008 6:43 pm    Post subject: Add User to Ignore List Reply with quote
Where you have cut your blocks at an angle you should put undercloak strips on which overlap the blocks by an inch or so. You then cement up the gap between the strip and the tiles.
Hope these foto's help explain things
 Description:
The thin strip in the undercloak which overlaps the bricks by and inch but level with the edge of the tiles
 Filesize:  44.36 KB
 Viewed:  439 Time(s)
 Description:
 Filesize:  57.35 KB
 Viewed:  439 Time(s)
 Description:
Cemented up
 Filesize:  43.16 KB
 Viewed:  439 Time(s)
Back to top
consquires
Junior Member
PostPosted: Sat Jul 12, 2008 4:01 am    Post subject: Add User to Ignore List Reply with quote
photos certainly help, what material would you use for undercloaking?
also what type of felt is used under tiles?
Back to top
skiking
PostPosted: Sat Jul 12, 2008 9:28 am    Post subject: Add User to Ignore List Reply with quote
Go to your local builders or roofers merchant and ask for undercloak - they'll know what you want - its like an asbestos strip, but not scratch . I think they come in 1.2mtr strips and double brick width.
The felt is Tyvek Supra (i think). Comes in huge rolls and is not cheap. If your in the Cheshire area you could have the rest of mine in exchage for some beer tokens Thumbright
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Building Forum All times are GMT
Goto page 1, 2  Next
Page 1 of 2
