Ultimate Handyman Home
porch roof
Goto page Previous  1, 2
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Building Forum
consquires
Junior Member
PostPosted: Sat Jul 12, 2008 6:04 pm    Post subject: Add User to Ignore List Reply with quote
will visit local builder, unfortunately would cost more to get to you than the cost of felt.
Live near Belfast.
Thanks for your help
Back to top
joiner_uk
PostPosted: Sat Jul 12, 2008 9:14 pm    Post subject: Add User to Ignore List Reply with quote
As skiking has explained with finishing the verge you can either finish with render (probably best) or finish with a barge board. A barge board would simply be a 6-8" piece of facia fixed to the brick work directley under the undercloak.
When fitting the undercloak bed this on with cement then use a straight edge ie 4x2" to tap down the undercloak.
Quote:
would not put a rafter on the outside wall just cut a short length with the birds mouth on then set inside the first block. You will then be able to finish the corner with a block cut down for rendering. Fix 2 noggins across to support the rafter, fix the top noggin as high up as you can probably on top of wall pate so only 2" high or so.
Have a look at pic to see what I mean. This last rafter helps support the facia.
 Description:
 Filesize:  57.83 KB
 Viewed:  296 Time(s)
Carpenter & Joiner Sheffield
Back to top
consquires
Junior Member
PostPosted: Sun Jul 13, 2008 5:33 pm    Post subject: Add User to Ignore List Reply with quote
thank you photo very good now know what you mean, will keep you posted with progress when I get home.
Back to top
consquires
Junior Member
PostPosted: Wed Jul 23, 2008 8:01 am    Post subject: Add User to Ignore List Reply with quote
Have done rafters as per your photo, now have put tiles on,see photos.
am away for another week on boat.
So will carry on when I get back ( weather permitting)
 Description:
 Filesize:  57.56 KB
 Viewed:  249 Time(s)
 Description:
 Filesize:  59.97 KB
 Viewed:  249 Time(s)
Back to top
joiner_uk
PostPosted: Thu Jul 24, 2008 4:09 pm    Post subject: Add User to Ignore List Reply with quote
Well done mate Thumbright looking good.
Did you fit the tiles yourself?
Back to top
PostPosted: Thu Jul 24, 2008 5:59 pm    Post subject: Add User to Ignore List Reply with quote
That is a nice neat job Thumbright
Thanks for posting the pictures, and thanks Joiner uk for the sound advice Wink
DIY | DIY Video
Back to top
consquires
Junior Member
PostPosted: Fri Jul 25, 2008 3:53 am    Post subject: porch roof Add User to Ignore List Reply with quote
Yes roof all my own work thanks to your sound advice. Now just need to finish flashing and mortar between tiles and undercloak. am putting concrete floor in any tips would be a help.
Thumbright
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Building Forum All times are GMT
Page 2 of 2
