Ultimate Handyman Home
Pond problems water under lining
Post new topic   Reply to topic   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Gardeners World
williams04
Junior Member
PostPosted: Tue Jul 08, 2008 7:15 am    Post subject: Pond problems water under lining Add User to Ignore List Reply with quote
Hi I am a new very depressed member at the moment, I have a pond which I thought was put down correctly but after this bad rain period I have now found that the lining is being pushed up as I seem to have lots of water sitting under the pond. My garden does not drain well and I do find water just sits around for ages.
I do not know what to do now I was thinking I could lift an area of the lining up and pump out the water but then this is just a temp soultion, if anyone has any ideas of what to do.
Back to top
joiner_uk
PostPosted: Tue Jul 08, 2008 10:35 am    Post subject: Add User to Ignore List Reply with quote
You will probablly have to drain the pond then pump out the water underneath the liner.
Are the pond walls level with the ground level?
If so to prevent the pond from having the same problem build the sides up so they are 4" or so above ground level
Carpenter & Joiner Sheffield
Back to top
williams04
Junior Member
PostPosted: Tue Jul 08, 2008 10:53 am    Post subject: Add User to Ignore List Reply with quote
Yes its level with the ground but no water poured into the pond just underneath, I am going to try to drain under the pond 1st.
Back to top
williams04
Junior Member
PostPosted: Tue Jul 08, 2008 1:23 pm    Post subject: Add User to Ignore List Reply with quote
I have managed to drain the water from underneath that pond vac came in handy, I think the problem is I came too close to the fence and now don't have a lot of options, need to stop the water coming down the fence and sitting there I suppose, I have took a picture if anyone has any more ideas but not sure how to upload it.
Back to top
joiner_uk
PostPosted: Wed Jul 09, 2008 8:55 pm    Post subject: Add User to Ignore List Reply with quote
Just use the 'Add an attachment' in the 'replypost' to upload a picture
Back to top
slippery
Junior Member
PostPosted: Wed Jul 16, 2008 6:48 am    Post subject: Add User to Ignore List Reply with quote
that will look nice!, and will definitely stop it!
is the pond at the bottom of a slope?
Back to top
Display posts from previous:
Post new topic   Reply to topic    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Gardeners World All times are GMT
Page 1 of 1
