It is currently Fri May 25, 2012 9:39 am
 Post subject: Pole Hook
PostPosted: Wed Mar 09, 2011 3:21 pm
Hello all
I have fitted two 10 foot, 1.5 inch diameter TV aerial poles at the end of a roof terrace to attach washing lines. I have a two line retractable washing line box attached to the house. The washing lines end with a plastic tab with a hole within them.
I am getting by through tying the lines round the poles when in use but I would ideally like some kind of hook on the end of the poles to easily affix and remove the lines.
Can anyone recommend a suitable hook?
More importantly, can anyone recommend a suitable method to attach the hook to the metal pole?
I was trying to look for a long threaded screw with a hook end that I could drill through the pole and then bolt the other end?
Anyone seen something like this or get a better suggestion.
Many thanks
Derek
 Post subject: Re: Pole Hook
PostPosted: Wed Mar 09, 2011 3:49 pm
Been thanked: 69 times
http://tinyurl.com/4su6sgs
or
http://tinyurl.com/489nk75
I'm sure you can get them cheaper by the time you have included postage. B&Q also sell them.
Mike
PostPosted: Wed Mar 09, 2011 8:41 pm
Has thanked: 6 times
Been thanked: 108 times
Just what i had in mind.
Obviously, youd need to use a nut either side of the pole. :thumbleft:
PostPosted: Thu Mar 10, 2011 12:14 pm
Thanks Hitch and Mike
That is just what I need, I've ordered a set and will be showing off my handiwork to the other half in due course!
