It is currently Wed May 22, 2019 10:52 am
 Post subject: Plugin EV Query
PostPosted: Sat Jan 05, 2019 8:53 pm
Has thanked: 2 times
Hi, I'm not too sure if this is the right place for.this query. I recently took delivery of a hybrid vehicle that takes an electric charge via an adapter intended to be connected via a 3 pin plug. Typically the charge lead is just too short to reach from the power socket in my porch to the vehicle. I was thinking about getting a heavy duty extension lead from Screwfix tomorrow until I can get a proper outlet installed next week. I suppose it's a question for the professionals but can anyone see an issue with me connecting the charger lead to an extension lead?
I saw this which has purchases from people that have used it for their EV https://www.screwfix.com/p/masterplug-1 ... -10m/44635
Hopefully someone can shed some light on this and maybe put my mind at rest. Thanks!
 Post subject: Re: Plugin EV Query
PostPosted: Sat Jan 05, 2019 9:57 pm
Has thanked: 41 times
Been thanked: 1480 times
Without specific details of the charger, it is not possible to give a definitive answer, but what I will say for sure is don't use that lead with it coiled up anywhere. If its a bit too long run it back and forth, not coiled. Check it's temperature as well, it should be cool enough to pick up at all times.
PostPosted: Sun Jan 06, 2019 11:33 am
Thanks, so it states in the manual that it's a Type 2 Charger. Service Entrance: 120/230V, upto 16A, 2-wire with safety ground.
Hope this helps :thumbleft:
PostPosted: Sun Jan 06, 2019 1:05 pm
Approved Electrician
Has thanked: 177 times
Been thanked: 598 times
Type 2 charging may be done with a normal 13A socket. The charging lead has the RCD and any control gear required built into it.
PostPosted: Sun Jan 06, 2019 1:18 pm
Yeah sure. The only problem is that the original lead is too short, hence the query over the extension lead?
PostPosted: Sun Jan 06, 2019 2:31 pm
Has thanked: 349 times
Been thanked: 1829 times
Those 'general specs' are useless. "Up to 16A....." can mean 1A (250 watts) or 16 A (4,000 watts) and any amount in between.
There should be actual current consumption figures (or even a VA rating) that will determine the type and length of cable you can use (the longer the cable, the heavier [i.e. cross-sectional area] the cable cores need to be).
Personally I'd use a longer cable but NOT via a plug extension - I'd remove the shorter cable and fit the longer one directly.
PostPosted: Sun Jan 06, 2019 5:28 pm
Has thanked: 65 times
Been thanked: 686 times
Did you not read the info that come with the car, a charge lead with a 3 pin plug will take 14+ hours to charge (4-6 hours if it is one of the new phev's with 30 mile range on battery), I suggest you get a proper charger fitted
The information would of come with the car regarding charging and a option to purchase the charger and cable at the time of order assuming you purchased it new
what make and model is the car ? most manufactures have deals in place for installation of a charger
It may also benefit you to know about the various charging networks Aswell
Electric Vehicle Man (was Electric Leaf Man) is a good source of knowledge
https://www.youtube.com/channel/UCigsK5 ... Y6f5qwRxkw
PostPosted: Sun Jan 06, 2019 6:34 pm
Thanks Bob, it states in the manual the type 2 charger supplied will charge the vehicle in 3 hours, which I'm confident of. I'm not questioning the amount of time it takes to charge. I think we run the risk of getting too far away from the original query over the use of a suitable extension lead here.
PostPosted: Sun Jan 06, 2019 6:37 pm
Has thanked: 45 times
Been thanked: 759 times
3 hours sounds dubious, is the battery only 36Ah?
PostPosted: Sun Jan 06, 2019 7:13 pm
Yes. And some else answered it correctly.
PostPosted: Mon Jan 07, 2019 11:25 am
I would not run it off a extension lead, if the connection eg. plug and socket is outside it needs to be IP rated, Is the charger its self ip rated ?
You have purchased a new car, why scrimp on £300-400 to get the charging setup right
3 hours is a fast charge on most phev's @ 11 or 22kwh, a 3 pin plug will give you 3kwh
What make and model of car ?
