Page 1 of 1
[ 4 posts ] |
| Author |
Message |
leethesparky
Posted: Wed Nov 16, 2011 9:09 pm |
| Newly registered Member |
Joined: Wed Nov 16, 2011 8:50 pm Posts: 2 Has thanked: 0 times Been thanked: 0 times
fitting an electric shower to replace one that works off the combi . Took off the mixer bar to find two 22 mm male threads protruding from tiles . Ok so far so good . Need to reduce down to 15mm to terminate into shower and one stop end as only cold feed required for electric shower . Fine . Went to plumbcentre and the guy sold me a reducer . The only thing is you take out the oliver from the connector to fit the reducer and now the 15mm tube wont stay in once tight . Am i just thick or how the hell do i sort this out . I'm not a plumber ! help me please
| Top |
thescruff
Posted: Wed Nov 16, 2011 9:27 pm |
| OAP |
Joined: Mon Mar 10, 2008 12:46 am Posts: 39985 Has thanked: 187 times Been thanked: 2114 times
Best post a pic of the fitting
_________________ If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here : donnas-dream-house-charity-t52110.html
| Top |
register or
log in
white pan man
Posted: Wed Nov 16, 2011 10:07 pm |
| Senior Member |
Joined: Thu Jul 07, 2011 11:42 am Posts: 775 Location: london Has thanked: 57 times Been thanked: 99 times
Well would have thought he would have given you a bent 3/4'' female to 22mm compression fitting with a 15mm reducing kit to fit in the 22mm compression side if you are doing that way,you need to but the olive kit in fitting to make joint with pipe
However I would have unscrewed the 22mm male thread fittings you were left with coming out wall and you will find you will be left with 1/2 female threaded fitting in wall that you could link up to easier and tidier
_________________ If you have found help on the UHM's forums,why not help out the UHM's Nominated Charity,find out more here donnas-dream-house-charity-t52110.html
| Top |
register or
log in
leethesparky
Posted: Thu Nov 17, 2011 9:47 am |
Cheers mate . Unfortunately only the thread is exposed and what i can see appears to be soldered on from behind . To get to anything more would mean destroying tiles and digging wall out which i would much rather avert as the tiles are old and huge . This would mean tiling it again from scratch . However the bent 3/4 to 22mm sounds like what I need . Thanks
| Top |
register or
log in
Page 1 of 1
[ 4 posts ] |
