Page 1 of 1
[ 6 posts ] |
| Author |
Message |
lagi
Posted: Sun Jul 12, 2009 11:54 pm |
| Senior Member |
Joined: Mon Dec 22, 2008 6:09 pm Posts: 1589 Has thanked: 80 times Been thanked: 38 times
I have a kitchen back door with two side windows either side. They came with the connecting bars, but since having the inside plastered i have noticed the plaster cracking on the lower half of both sides of the frame. Obviously this is where there is movement.
The outside is brick then it goes to block and this is set back to allow for render. There are 2 screws in each side on the bottom half of the door.
Outside is not rendered yet so should i add more screws (on the bottom halves)???
There is some foam in there against the recessed blocks but should i try and get some in against the bricks also?
| Top |
Posted: Mon Jul 13, 2009 1:32 am |
| Pro Carpenter |
Joined: Sat Dec 16, 2006 10:11 pm Posts: 10519 Location: redhill surrey an auld reekie laddie Has thanked: 134 times Been thanked: 473 times
are you saying its rendered up to the plastic!!!
if so you ideally need a molding similar to a architrave to take up movement and cover the surface to hide movement
_________________ we are all ------------------still learning
| Top |
register or
log in
lagi
Posted: Mon Jul 13, 2009 7:57 am |
| Senior Member |
just given it another shake down, there is movement at just below window sill height. Having looked at the positions of the other two screws which are much lower i think it needs one either side as high as possible to stop it moving.
Then i can try some moulding on the inside if it still cracks.
| Top |
register or
log in
iceni
Posted: Thu Jul 16, 2009 7:35 pm |
| Senior Member |
Joined: Wed Aug 01, 2007 4:53 pm Posts: 185 Has thanked: 1 times Been thanked: 7 times
If you add another screw you will need to slide a packer in between the frame and the wall where you positon any new screw.
If not the plastic door outer frame will be distorted.
Inserting the packer / packers is not a problem but you will obviously need to cut the plaster away at that point to gain access to the gap between the frame and the wall
_________________ If you ask enough people, one will have the answer!
| Top |
register or
log in
leebwk
Posted: Thu Jul 16, 2009 8:40 pm |
| Senior Member |
Joined: Fri Dec 01, 2006 8:16 am Posts: 1591 Location: Oxford Has thanked: 3 times Been thanked: 30 times
You could add another couple of fixings but you will not eradicate all the movement and vibration from the door, as Big-all has stated you should really silicone a moulding around the door internally to bridge the movement cracks
_________________ If you think nobody cares, try missing a couple of payments..
| Top |
register or
log in
lagi
Posted: Thu Jul 16, 2009 10:30 pm |
| Senior Member |
I have fitted two more screws either side and bought some packers to make it a tight fit. Also got some foam to put above and below packers to fill the voids.
I have caulked this and your right, its better but there is a little movement.
I am intending to paint this shortly, so can i stick this moulding on after??? I won't be slamming the door in between.
Also on the side the hinges are, there isn't a lot of clearance between them and the side, about 10-15mm max, what sort of moulding are you thinking of???
| Top |
register or
log in
Page 1 of 1
[ 6 posts ] |
