Ultimate Handyman Home
Plastic pipe work on central heating
Post new topic   Reply to topic   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum
Hardip
Junior Member
PostPosted: Sat Sep 27, 2008 11:16 pm    Post subject: Plastic pipe work on central heating Add User to Ignore List Reply with quote
How prolific is the use of plastic piping on central heating systems?
Is it realistic/safe to replace copper directly with [rated] plastic pipe work?
Cheers,
Hardip.
Back to top
PostPosted: Sat Sep 27, 2008 11:35 pm    Post subject: Add User to Ignore List Reply with quote
out of sight and not within 2m off the boiler quite common
Back to top
Stoday
Electricity economics consultant
PostPosted: Sun Sep 28, 2008 12:52 am    Post subject: Add User to Ignore List Reply with quote
You wouldn't want to use anything other than plastic for underfloor heating laid directly in the screed.
Ask not for whom the bell tolls...
Back to top
thescruff
PostPosted: Sun Sep 28, 2008 12:54 am    Post subject: Add User to Ignore List Reply with quote
Indeed in modern rabbit hutches chucked together as houses you will see little else. However for quality and larger jobs Copper is still king.
How save is it depends on luck, Vermin of all kinds from mice, rats and squirrels love to feast on the stuff, fittings do and will continue to leak however carefull you are.
Scruff
Back to top
Hardip
Junior Member
PostPosted: Sun Sep 28, 2008 10:01 am    Post subject: Add User to Ignore List Reply with quote
That is a very specific application. I noticed on some new builds (and not necessarily the cheap kind) there were instances of plastic pipe work on radiators. I'm not sure if it went any deeper than that... scratch
Back to top
Stoday
PostPosted: Sun Sep 28, 2008 1:52 pm    Post subject: Add User to Ignore List Reply with quote
I was showing that plastic is OK, Hardip.
Helps lazy plumbers too, because it won't creak when it heats & cools like copper does if you don't use felt pads.
For a quality job though, it's copper with end-feed fittings, except for UFH of course.
Back to top
Mooncat
PostPosted: Sun Sep 28, 2008 8:49 pm    Post subject: Add User to Ignore List Reply with quote
I seem to remember a pipe product from Autocon, warranted to last 25 years, but did the company last that long.
Back to top
Mooncat
PostPosted: Sun Sep 28, 2008 8:50 pm    Post subject: Add User to Ignore List Reply with quote
Felt pads? How and where?
Back to top
thescruff
PostPosted: Sun Sep 28, 2008 9:00 pm    Post subject: Add User to Ignore List Reply with quote
Anywhere where the pipe touches wood or plaster.
Scruff
Back to top
Hardip
Junior Member
PostPosted: Mon Sep 29, 2008 10:11 am    Post subject: Add User to Ignore List Reply with quote
Are we talking standard felt pads, the sort you may use on furniture and other bits?
Back to top
thescruff
PostPosted: Mon Sep 29, 2008 10:22 am    Post subject: Add User to Ignore List Reply with quote
Anything that comes to hand really, plumbers would normally use hair felt lagging cut into strips.
DPC cut into strips is good as well, all you are doing is keeping the pipe from the wood to stop it creaking.
If you have Oak joists or boards, then you must use the waterproof DPC or other plastic as the acid in green oak will eat through copper in weeks.
Scruff
Back to top
Hoovie
Devon DIYer
PostPosted: Mon Sep 29, 2008 10:38 am    Post subject: Add User to Ignore List Reply with quote
Don't you see a lot of plastic in new builds at least partly to avoid tempting passing scrotes to have it away with the copper pipes while they are nice and accessible?
I much prefer the idea of copper personally - tried and tested. If it ain't broke ......
If you have a son, DO NOT name him after a verb ....
"Which is it, man?"
Back to top
justlead1
Junior Member
PostPosted: Mon Sep 29, 2008 2:53 pm    Post subject: Plastic pipe work on central heating Add User to Ignore List Reply with quote
Hi.Interesting question. The answer every body seems to us it. It is also the same question someone asked me relating to waste & soil pipe/fittings some 35 years ago. Funny old game, a fortnight ago a 32 year old plumber asked if i knew how to bend 32mm copper pipe. I found the question quite sad as he is a dedicated plumber. Supply and demand seems to = fir coat no knickers. Good Luck
Back to top
Steve the Gas
PostPosted: Tue Sep 30, 2008 3:08 am    Post subject: Add User to Ignore List Reply with quote
I'll bet Scruff don't use it.
I do,only when appropriate though, on hidden work only for e.g.
Back to top
mac321
Junior Member
PostPosted: Thu Oct 02, 2008 6:43 am    Post subject: Add User to Ignore List Reply with quote
used it for my heating (bar copper near to boiler). No joints in roof/floor space, simple distribution points, 10mm feeds to rads/TRV (come through wall behind rads so not visible).
Horses for courses really. Quicker, simpler than copper, cleaner and no hidden joints. As for longevity.....will let you know in a few years Smile
M
Back to top
Display posts from previous:
Post new topic   Reply to topic    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum All times are GMT
Page 1 of 1
