Ultimate Handyman Home
Plastering onto non-sealed Plasterboard
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plastering Forum
JessicaJC
Junior Member
PostPosted: Wed Aug 15, 2007 10:23 am    Post subject: Plastering onto non-sealed Plasterboard Add User to Ignore List Reply with quote
Help! Can anyone give me some advice please?
I have recently bought a house (1960's) and am stripping the walls of all the old wallpaper, with a view to getting them replastered. The problem I have is that the walls have never been skimmed and the previous owners wallpapered straight onto the plasterboard. Now I am trying to remove it, the bottom layer of wallpaper has stuck to the board and its tearing off the top layer of the plasterboard and exposing the cardboard layer.
I have had one plasterer say that this cant be replastered as the new plaster will fall off. Is this the case? Cant extra PVA be added to seal it?
I dont really want to go through putting up new plasterboard as it will have to be added on top as I have 'laminate' walls which need to be completely removed (which I really dont want to do) and if I add it on top it will mean refitting door frames etc.
Any advice gratefully received!
Back to top
leebwk
PostPosted: Wed Aug 15, 2007 11:39 am    Post subject: Add User to Ignore List Reply with quote
Hi Jessicajc,
If you can remove the wallpaper without tearing off the plasterboard backing ie the brown papered side of the plasterboard then you should be ok but i feel this will be quite a tricky if not impossible task if the wallpaper is stuck down well
What was the best thing before sliced bread?
Back to top
JessicaJC
Junior Member
PostPosted: Wed Aug 15, 2007 11:46 am    Post subject: Add User to Ignore List Reply with quote
Thanks for replying. We cant get the paper off without taking off the plasterboard backing, as the last layer of wallpaper as adhered to it.
Do you think you can plaster over this if we have exposed the base layer of plasterboard?
Back to top
leebwk
PostPosted: Wed Aug 15, 2007 12:09 pm    Post subject: Add User to Ignore List Reply with quote
Not really Jessica as this is partly what gives plasterboard it's structural strength and if it get's knocked it will just collapse in on itself, personally i would removeand re-board then re-skim, failling that i would board over the top and extend the door linings with some planed timber ie door stop.
Hope this helps
Back to top
andy-p-
pro plasterer
PostPosted: Thu Aug 16, 2007 4:23 pm    Post subject: Add User to Ignore List Reply with quote
yeh i agree, never skim over wallpaper, dont care wot some spreads say
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plastering Forum All times are GMT
Page 1 of 1
