It is currently Fri May 25, 2012 9:04 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 7 posts ]
PostPosted: Thu Jun 02, 2011 5:21 pm
Im tiling a bathroom but after taking tiles off that were half up the wall, the plaster is coming off back to the brick. Should I use sand/cement render or is there another base coat i could use, dont want to use bonding.
thanks
PostPosted: Thu Jun 02, 2011 6:41 pm
Has thanked: 2 times
Been thanked: 1 times
Browning?
http://www.british-gypsum.com/products/ ... wning.aspx
PostPosted: Thu Jun 02, 2011 6:49 pm
Has thanked: 1 times
Been thanked: 5 times
Are you putting tiles back on the wall, if so what type, and size, this could influence what you do to the wall
PostPosted: Thu Jun 02, 2011 7:09 pm
The tiles are ceramic, that are going back on 12 x 8 roughly
PostPosted: Thu Jun 02, 2011 9:02 pm
OK so you need to know the weight of the tiles per sq Mtr, Plaster skim will take 20Kg/SqMtr including adhesive and grout which weighs in at approx 4Kg/SqMtr, if your tiles fall into this no problem, if not, you may be better dot & dabbing plasterboard, and mechanically fixing through the dabs, this will allow up to 32Kg/SqMtr, and you can skim any bits that are to be painted and tile onto the bare board.
For that size tile i would say its right on the edge regarding tubbed adhesive, personally i would use a powdered cement based adhesive.
Hope that helps.
PostPosted: Thu Jun 02, 2011 11:39 pm
im a tiler, and never use tubbed gear, always cement based
PostPosted: Fri Jun 03, 2011 6:52 am
Taht will be alright then
