Ultimate Handyman Home
Plasterboard
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plastering Forum
kev1628
Junior Member
PostPosted: Fri May 25, 2007 9:40 am    Post subject: Plasterboard Add User to Ignore List Reply with quote
Hi there,
Hope someone can help,bear with me on this!I have just knocked back to bear brick in an upstairs bedroom,and intend to dot and dab plasterboard onto the walls,then get them plastered.The walls are quite high as it is an old house,they measure about 2640mm floor to ceiling.Now am I right in thinking that plasterboard comes in sheet 2400mm high/long?If so is it ok to cut a bit of board to make up the shortfall,and would you put the piece at the top or the bottom?Hope this makes sense! :grin:
Cheers Kev
Back to top
skiking
PostPosted: Fri May 25, 2007 11:04 am    Post subject: Add User to Ignore List Reply with quote
They also come in 2700x1200
Back to top
kev1628
Junior Member
PostPosted: Fri May 25, 2007 12:01 pm    Post subject: plasterboard Add User to Ignore List Reply with quote
Cheers for that Skiking,a simple answer to rambling question! Laughing
Back to top
steves plastering
PostPosted: Tue Jun 12, 2007 11:35 am    Post subject: Add User to Ignore List Reply with quote
however, if you cannpt get the boards in in that size then place the shortfall bit on the top, it can rest on the fixed board below and will be easier to fix up than a whole board with a big gap beneath it.
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plastering Forum All times are GMT
Page 1 of 1
