-> Plastering Forum |
| Author |
Message |
andy-p- pro plasterer
Posted: Sat Jun 09, 2007 6:00 am Post subject: |
Or.. maybe plasterboard the whole bathroom and use a tanking kit where the shower is going. £50 and youll have half left over to do your en-suite your miss's will have you doing next.lol.
It provides a waterproof barrier.Cheaper that aquapanel.
Just another option  |
| Back to top |
steves plastering Senior Member
Joined: 05 Jun 2007 Posts: 129 Location: Newcastle upon tyne
Posted: Sat Jun 09, 2007 8:27 am Post subject: |
fair point, is it ok to tile on normal plasterboard or should it be skimmed first??
I can dot and dab 9.5mm board everywhere but the shower (where it will be aqua panel) but the whole room is to be tiled so not sure if i need to skim??
Still.....can aquapanel be dot and dabbed over the brick with dry wall adhesive?? It would be so much quicker!! |
| Back to top |
ultimatehandyman Site Admin
Joined: 16 Jul 2005 Posts: 9769 Location: Darwen, Lancashire
Posted: Sat Jun 09, 2007 8:54 am Post subject: |
Still not sure about this, non of the people on here that would know have been on to answer this.
I'd screw it to the wall using rustprrof screws and wall plugs to be on the safe side, you don't want it dropping off in a few months.
You can tile straight onto the plasterboard, no need to skim it first. _________________ DIY | DIY Video |
| Back to top |
Posted: Sat Jun 09, 2007 4:27 pm Post subject: |
Fair point uhm.
Another way....I skimmed a loft conversion for a builder 3 months ago.
There was a shower room put in as well. the builder used wbp ply to line the shower room. The tiler (a tradesman tiler) justed primed it and tiled straight on top.
I asked both of them about this ply as ive not seen people put it in shower roome before, they both said its fine.
Steve, heres a tiling link. Ask the same question, see what they recommend.
www.tileforums.com. click on the 1st one.
Uhm hope it is ok to put is link up, i was not sure.?? If not soz |
| Back to top |
Posted: Sun Jun 10, 2007 11:03 am Post subject: |
| thanks for the link, i'll try. |
| Back to top |
marksson Senior Member
Posted: Sun Jun 10, 2007 9:37 pm Post subject: |
With gadget,
Use whatever you need to in the shower and then if spec requires it dot & dab the rest with moisture resistant plasterboard. _________________ Building Materials Sourcing
Softly, softly catchee monkey |
| Back to top |
Posted: Wed Jun 13, 2007 9:56 am Post subject: |
I e-mailed Knauf a few days ago to get confirmation directly from themselves as to whether or not you can direct bond aquapanel and then tile on top of it. I received an e-mail saying they received my e-mail but as yet I have had no response from them. _________________ DIY | DIY Video |
| Back to top |
Posted: Wed Jun 13, 2007 7:05 pm Post subject: |
| very kind of you UHM, thanks very much |
| Back to top |
Posted: Fri Jun 15, 2007 3:14 pm Post subject: |
Knauf technical have now replied and have sent a brochure for installing aquapanel. I have made a sticky post in the tiling section-
dot & dab Aquapanel _________________ DIY | DIY Video |
| Back to top |
Posted: Fri Jun 15, 2007 7:37 pm Post subject: |
Thanks very much UHM, sounds like aquapanel isn't as easy as i thought(it doesn't get any easier than dot and dab), do people often cut the corner of just putting normal plasterboard up? Not that i plan to do this
I have seen a few bathrooms put in and it seems to be just plasterboard all the way round and then tiles over??
Is this a cheap and naughty way of doing it or for domestic light use is it OK? |
| Back to top |
Posted: Fri Jun 15, 2007 9:04 pm Post subject: |
As long as it is not in the shower area I guess it should be ok. _________________ DIY | DIY Video |
| Back to top |
Posted: Fri Jun 15, 2007 9:22 pm Post subject: |
a compromise
| Quote: |
| moisture resistant plasterboard |
| Back to top |
Posted: Sat Jun 16, 2007 3:58 am Post subject: |
| marksson wrote: |
a compromise
| Quote: |
Isn't that the same as aquapanel?
Aquapanel is moisture resistant plasterboard  _________________ DIY | DIY Video |
| Back to top |
Posted: Sat Jun 16, 2007 6:17 am Post subject: |
Taken off the Knauf site
| Quote: |
| Knauf Moistureshield is a high performance plasterboard for use in internal areas of high humidity and temporary external exposure. Knauf Moistureshield complies fully with BS EN520 and is categorised as Types A, H1, H2. |
| Quote: |
| Knauf Aquapanel is a glass fibre reinforced cement board for use as a tile backer in wet and humid areas. Will not rot or warp. Can be used for internal and external applications. |
Whilst I wouldn't guarantee it, I think that the mosture resistant plaster board is gypsum based (got little fibres in it) and therefore OK to dot & dab with. I'm sure that I have in the past. _________________ Building Materials Sourcing
| Back to top |
Posted: Sat Jun 16, 2007 1:35 pm Post subject: |
Knauf could of told me that
At least that is cleared up  _________________ DIY | DIY Video |
| Back to top |
