It is currently Fri May 25, 2012 8:54 am
 Post subject: Plaster next to window
PostPosted: Wed Jul 13, 2011 11:56 am
Has thanked: 5 times
Hi again :D
So I've moved on to the window, where the plaster is not in very good condition. When I touched the section to the right of the window, it seemed that a very thick layer of plaster was moving, which was cracking the skim. I realised that this problem would only get worse if I just papered over the cracks, so I chipped off the section that moved and cracked. The worst part of the damage is smaller than my outstretched hand but bigger than my palm. I am already putting a couple of extra screws in the angle bead, but I will need to get something under the bead.
I was going to patch up the corners with Easi-Fill anyway, so am I going to be able to get away with several layers of Easi-Fill again?
Thanks in advance
PostPosted: Wed Jul 13, 2011 8:09 pm
Has thanked: 44 times
Been thanked: 114 times
should be ok, provided you layer it as you say, give it a lick of pva first (2:1 water:pva)...
For this message the author cwplastering has received gratitude : MariaTurk
PostPosted: Wed Jul 13, 2011 11:28 pm
Thanks CW. I'll let you know how that goes. :-)
PostPosted: Fri Jul 29, 2011 1:24 pm
Hi, I'm back. I applied some pva like you said, but the landlord shoved some quick cement in the hole. I scraped some off and layered up the Easi-Fill, building up the corner because the bead was showing. Time to start undercoating next...
Big thanks to all :-)
