dont even remember makin that post the other night..
looking at it, just seems the old paint wasnt keyed well enough to the plaster... prolly never got a mist coat and just wallop, neat out the tub rollered on...
you get the same thing with distemper too.... great well entire ceiling waits till your almost at final trowel then starts to debond... next thing you know its changed its name to 'carpet'...
good cure for distemper is bonding agent, sort of binds it together and sticks it to the wall as well as gives you some sand back as a key..
skimming over paint always carried an element of doubt with it... It happens to us all on occasion and to be honest, all i normally do is cut out the blister, quick lick some pva on it and fill it back in either with a bit of fresh mix or the same mix if theres enough left.... preferably not to 'fatty' so it wont shrink..
i had 3 full walls do that to me over christmas... pva'd, skimmed and troweled up... day later they hanging by the corners, you could poke your finger through the middle, like an easter egg... or just wobble the entire wall... 1 big sheet, give it a tug and its on the floor...
next day the other walls are off too... 1 board wall saved me the whole room
rollered em with bonding agent and skimmed next day, problem solved...
