Ultimate Handyman Home
Plaster boarding around door
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Building Forum
devlin
Member
PostPosted: Mon Mar 19, 2007 10:04 pm    Post subject: Plaster boarding around door Add User to Ignore List Reply with quote
Hi Guys
How do I plaster board around a door frame without the edge showing between facing and frame, Do I use a strip of timber like 1/2 from frame edge same thickness as the board or is there a profile facing can buy ???
devlin
Back to top
PostPosted: Mon Mar 19, 2007 10:26 pm    Post subject: Add User to Ignore List Reply with quote
I'm not aware of any edging and so would use the timber Wink
DIY | DIY Video
Back to top
tim'll fix it
PostPosted: Mon Mar 19, 2007 10:27 pm    Post subject: Add User to Ignore List Reply with quote
the door frame should cover the edge of the plasterboard
it sounds like you are overboarding something and your door lining arnt wide enough
I would put wider door linings in
Decking
Back to top
Slugster
PostPosted: Tue Mar 20, 2007 9:11 am    Post subject: Add User to Ignore List Reply with quote
If the situation is as Tim describes it, I've been there myself.
On walls where the new boards really do stick out proud from the wall by a good 1/4" I used wider door linings.
But if its a matter of ball hairs I took a door surround and routed a recess down the entire length on the plasterboard side. I only had to take it down a few 1/16ths for it to fit snug as a bug...
Back to top
devlin
Member
PostPosted: Thu Mar 22, 2007 1:28 pm    Post subject: Add User to Ignore List Reply with quote
Hi Again
Thanks guys it,s simple when it,s explained I was indeed overboarding door lining wrong size I used a 4" instaed of 5"
Thanks Dev
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Building Forum All times are GMT
Page 1 of 1
