It is currently Mon May 21, 2018 8:26 am
Post new topic Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
 Post subject: Re: Planes...
PostPosted: Sun Apr 16, 2017 12:33 am
Has thanked: 375 times
Been thanked: 1359 times
Rorschach wrote:
No problems with the frog side of the mouth it seems, just narrow in general, when the blade is out enough to take a cut there is hardly any room for the chip.
I had to file the back of the throat off on all three of my Stanleys, two Smoothers and a Jack- when I'd finished, the angle matched the angle that the frog makes as it leaves the sole plate (on the casting it's usually much steeper) and also meant that the frog had to be moved back (about 3-4mm from memory) this will open up the throat and leave more room at the front.
PostPosted: Sun Apr 16, 2017 7:18 am
Has thanked: 41 times
Been thanked: 616 times
Ok I'll take another look when I get chance.
PostPosted: Tue Apr 18, 2017 8:52 pm
Has thanked: 42 times
Been thanked: 1 times
I've never had a plane yet that didn't need a lot of fettling! Unless you've won the Lottey and can spend £100+ on a Veritas or Lie-Nielsen plane, then I reckon fettling is required. YouTube has lots of good videos about how to sort hand planes, from smoothing the sole to sharpening the blade.
However, excellent replacement blades can easily obtained. E.g. Ron Hock blades are superb, which you can obtain in the UK from ClassicHandTools.com. Quangsheng are excellent too.
PostPosted: Tue Apr 18, 2017 9:11 pm
Old School Chippie
Has thanked: 656 times
Been thanked: 1354 times
Fancy_Dan wrote:
I've never had a plane yet that didn't need a lot of fettling! Unless you're spending upwards of £100+ on a Veritas or Lie-Nielsen plane, then I reckon fettling is required
Tried a Wood River, Quangsheng or von Berger (from Bill's Tools in Glasgow)? They still require fairly minimal fettling, many are under the £100 figure and they are streets away from Silverline or Draper (or for that matter modern Record) in terms of accuracy and finish. BTW, when I started using planes professionally more than 40 years ago a small amount bof fettling was still required.... One thing, though, is that if you want a good, slop-free blade adjuster, you still need to go Clifton (remember them? British!), Veritas or Lie-Nielsen. Nothing else is ever as good -m even a 50 year old Stanley or Record
Why buy American when you can buy British? Ray Iles (one of Ashley Iles' sons) makes excellent quality O1 carbon steel blades in the UK, available from Workshop Heaven (amongst others). Every bit as good as Ron's products. Unlike Hock irons they have the more familar bevel top style we are all used to, so they look better, too (well, I hink so). Ray makes irons (for bench planes) in standard thickness (which will fit directly into any bench plane without modification) and in a thicker version (which will require the mouth to be eased with a file). Clifton "Victor" brand irons (also made in Britain, in Sheffield) are uniquely hand forged and are another top blade, with better edge characteristics than Veritas carbon steel blades, IMHO. Available from Workshop Heaven, Classic Hand Tools, Axminster, etc. For a cheapie, but nonetheless reasonable blade, you could always buy one of the Quangsheng blades - OK, so they are Chinese, and thicker than standard irons (so you need to open the mouth a bit) but they are pretty decent irons, being made from T10 tool steel (quite similar to our O1) and do hold an edge quite well - far better than any modern Stanley or Record I've used
For this message the author Job and Knock has received thanks - 2: Fancy_Dan, getthewheelsinline
