It is currently Sat Jun 23, 2018 5:30 am
 Post subject: PIR Light Switch problem
PostPosted: Fri Sep 22, 2017 12:22 pm
Has thanked: 11 times
Been thanked: 2 times
Hi All
I've bought a PIR light switch for the bathroom to replace the pull cord. The existing switch simple has a red and a black and an earth. The new switch has main in, but it also has a "load loop". The live is linked to the live on the loop, but the other connection has nothing. If I connect up the mains in, the lights just flash on an off quickly.
I'm sure I must need to do something to the load side of the switch, but there was no comparable connections previously. I'm ok with basic electric, but this is beyond me!
Any ideas?
Mike
PostPosted: Fri Sep 22, 2017 12:35 pm
Has thanked: 1052 times
Been thanked: 978 times
The PIR unit will need:
a permanent live (which you have)
A neutral (which you don't have. The black wire is probably the switched live to the light)
The red and black might be reversed though.
Be careful.
Power off.
For this message the author Dave54 has received gratitude : multiman
PostPosted: Fri Sep 22, 2017 12:38 pm
ahh, yes, I have live and switched live. I think I need a sparky then...
For this message the author mikehibbert has received gratitude : multiman
PostPosted: Fri Sep 22, 2017 3:01 pm
Ok, thinking this through...
I have a lighting circuit. and the switch is simple a cut in the live feed with the existing switch providing the connection when it's "on". So there's a neutral in the loft somewhere, that goes to the light, the light and the switch are only a foot or so apart, so I can sort this.
Is there a rough sketch that shows the connections?
PostPosted: Fri Sep 22, 2017 7:29 pm
Has thanked: 42 times
Been thanked: 1266 times
What is the make / model of the switch? (Most, but not all need a neutral) Also what are the lamps you have?
PostPosted: Sat Sep 23, 2017 8:58 am
Thanks for the reply. We're away for the weekend so I can't recall the name of the switch. I'll check on Sunday.
It has a live neutral and earth, plus a separate loop for the load.
The lights are LED.
I think I need to get a neutral and live from the lighting loop somehow just not quite sure of the config.
PostPosted: Sat Sep 23, 2017 9:11 am
If it has a neutral, should be no problem. Perhaps a picture or two would help.
PostPosted: Sat Sep 23, 2017 6:25 pm
Has thanked: 696 times
Been thanked: 28 times
Your best option would be to run 3 core and earth that way you have live, switched live and neutral then configure at fitting side you may have another light looped into circuit
PostPosted: Sun Sep 24, 2017 10:21 am
Approved Electrician
Has thanked: 162 times
Been thanked: 562 times
Either that or use a singles cable eg 6181Y to provide a neutral.
For this message the author OnlyMe has received thanks - 2: Dave54, multiman
PostPosted: Tue Sep 26, 2017 10:06 am
Thanks for all the replied folks. I think I have an answer now. The switch and the light are close(ish) together, so I can run a neutral from the light fitting to the switch and all should be well. Thanks for the pointers!
