It is currently Sat Feb 17, 2018 9:07 pm
Visit Thermo worx
PostPosted: Sun Oct 22, 2017 9:19 pm
Has thanked: 1 times
I've just put a latern with a pir on it. The sensor adjust up and down vertically. Will it have the maximum distance if it's pointing straight or does the distance reduce as it angles down
PostPosted: Sun Oct 22, 2017 10:59 pm
Has thanked: 38 times
Been thanked: 1178 times
It depends on the way the sensor and its lens is configured* as to how far it can "see"
The "norm" is that the sensor looks at a downward angle, so the further down you angle it the less distance away it can "see"
Also bear in mind that a PIR is more sensitive to movement across its field of view than towards its field of view.
* You can get different lenses for some PIR detectors.
For this message the author someone-else has received gratitude : mawallace
PostPosted: Mon Oct 23, 2017 12:05 am
Has thanked: 147 times
Been thanked: 217 times
PIR sensors use linear fresnel lenses. I'm certainly not an expert on optics, but the entire point of this type of lens is to absorb light from a large area with no specific central focal point (or to spread light linearly over wide area, which is why they're used in lighthouses). Moving it around will have an effect on the region it captures heat/light from, but shouldn't have a huge effect on the range for the area it can actually see. The more common problem is that they capture movement from too wide an angle, which is why many PIR sensors come with little plastic blanking clips to allow you to mask off areas to avoid unwanted triggering.
For this message the author chrrris has received gratitude : multiman
PostPosted: Mon Oct 23, 2017 6:34 am
Has thanked: 41 times
Been thanked: 578 times
What do the instructions say? Usually they have a diagram show the distance and spread.
For this message the author Rorschach has received gratitude : multiman
PostPosted: Mon Oct 23, 2017 7:05 am
That is why I asked - there is no mention in the manual! (which is next to useless!)
PostPosted: Mon Oct 23, 2017 5:58 pm
As I said previously, it depends on the lens that is fitted to the PIR as to how far forward it can see (Within reason)
Also I neglected to mention the mounting height, again the higher up it goes the further it can see, the down side is it also means most PIR's can not see anything close to them if they are high up.
If it were me I would put it up just out of arms reach and alter the angle of the sensor.
