It is currently Fri Apr 20, 2018 9:19 am
 Post subject: Pinhole radiator leak
PostPosted: Tue Feb 01, 2011 5:50 pm
Hi
I recently took a radiator off the bedroom wall to redecorate. When i put the radiator back on the wall it had developed a small pinhole leak in the center of the radiator at the bottom. It is an old system and old radiator.
I know that leaks like this are often caused by sludge/rust and air in the system which is probably true in this case. I will flush the system out and add a relevant cleaning chemical.
Just wondering if there is anyway i can repair the existing radiator with the small leak or do i have to completely replace the radiator?
Cheers
PostPosted: Tue Feb 01, 2011 5:56 pm
Has thanked: 662 times
Been thanked: 1896 times
nope you need another radiator as there will be rust all over the place thinning the metal and this is just the first off many holes to apear
if you radiator is imperial in length then your metric will be shorter and require the use off adjustable tails
http://www.screwfix.com/prods/15531/Plu ... ompression
PostPosted: Tue Feb 01, 2011 5:59 pm
Has thanked: 422 times
Been thanked: 3903 times
You should also be wary of using chemicals etc on an old system, as you may find quite a few more leaks.
A cold flush is all I would recommend, and then add the inhibitor after you test.
PostPosted: Tue Feb 01, 2011 8:47 pm
Has thanked: 785 times
Been thanked: 847 times
Keep an eye on the other rads, as quite often, but not always, when one pin holes there will be others :cb
Dave
www.drlgas.co.uk
Users browsing this forum: blawford and 3 guests
