Page 1 of 1
[ 5 posts ] |
| Author |
Message |
colray47
Posted: Sat Aug 27, 2011 12:45 pm |
| Newly registered Member |
Joined: Fri Jan 21, 2011 11:26 am Posts: 8 Has thanked: 15 times Been thanked: 1 times
Hi. Hope someone can help please. I have a citreon picasso 52 reg the screen washer doesn't work I can hear the pump motor working but nothing comes out front or back, the bottles full and i can't see any leaks any suggestions what to do next please.
For this message the author colray47 has received gratitude : Dene |
| Top |
dave.m
Posted: Sat Aug 27, 2011 2:13 pm |
| Senior Member |
Joined: Tue Jun 09, 2009 5:30 pm Posts: 5069 Location: A Yorky in Lancashire Has thanked: 16 times Been thanked: 338 times
Can you remove the bottle and see if it is gundged up at the bottom where the water goes to the pump? Don't know if the pump is in the bottle or separate, but if separate, try taking the pipe of the from the bottle to the pump and clearing it out. dave
_________________ You can always tell a Yorkshireman,
But you cannot tell him much.
| Top |
register or
log in
Hitch
Posted: Sat Aug 27, 2011 5:51 pm |
| Senior Member |
Joined: Mon Jan 16, 2006 8:16 pm Posts: 4674 Location: Somerset Has thanked: 6 times Been thanked: 108 times
Pull the hose of wherever, nearest the tank and try it. if nothing, might need to take the pump off and give it a clean. Have you got an air compressor? give it a blast down the hoses if you have to dislodge any junk.
_________________ Why isn't the number 11 pronounced onety one?
For this message the author Hitch has received gratitude : colray47 |
| Top |
register or
log in
wrinx
Posted: Sun Aug 28, 2011 12:09 am |
| Senior Member |
Joined: Mon Nov 23, 2009 8:57 pm Posts: 363 Has thanked: 25 times Been thanked: 24 times
Another thought, can you see any fluid underneath the car after activating the washers? This would indicate a leak...in my experience it's been the result of a broken non-return valve under the scuttle panel.
wrinx
_________________ www.ilmostro.co.uk
For this message the author wrinx has received gratitude : colray47 |
| Top |
register or
log in
colray47
Posted: Sun Aug 28, 2011 8:25 pm |
Hi. problem solved I removed the motor from the bottom of the water bottle then removed the plastic part from the motor that the washer tubes are connected to. I then prised this piece apart. Inside is a rubber barrel encased in a small plastic tube. The rubber barrel pokes out each end of the tube and this slides along inside the casing so that when the front windscreen washer is used the small rubber barrel slides along inside and blocks off the rear screen washer and vicer versa. From what I could see the rubber over time had expanded in length and would not slide at all and was in effect blocking both ends. To rectify this I cut a sliver of the rubber one end so it could slide easier and now it works perfectly. The hardest part was gaining access to the water bottle under the wing but you only need to remove the clips on the front half of the plastic protector lining on the wing to gain access. Hope this helps others.
| Top |
register or
log in
Page 1 of 1
[ 5 posts ] |
