| Author |
Message |
Cookie
Posted: Sun Nov 27, 2011 9:10 am |
| Newly registered Member |
Joined: Sun Sep 18, 2011 7:59 pm Posts: 33 Has thanked: 4 times Been thanked: 0 times
I'm currently renovating my kitchen and as part of this I have run some PEX pipe for the hot water, there is a length of about 4M going across the wall. I have pipe clips about every 18" or so. Anyway It all works fine and looks nice and neat until I run the hot water, then the pipe flex's and becomes quite 'wavy'. Is this normal? Should I have more clips. The pipe will eventually be hidden so it dosen't matter what it looks like, but it just suprised me how wavy it becomes with the hot water running.
| Top |
thescruff
Posted: Sun Nov 27, 2011 9:30 am |
| OAP |
Joined: Mon Mar 10, 2008 12:46 am Posts: 39985 Has thanked: 187 times Been thanked: 2114 times
How do you mean wavy, flaps about or drapes, and does it straighten again. How hot is the water Stiff lagging would help. What is the brand make/model. Your bit's should be in Monday hopefully.
_________________ If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here : donnas-dream-house-charity-t52110.html
| Top |
register or
log in
Cookie
Posted: Sun Nov 27, 2011 9:57 am |
It drapes and yes it straightens again. The water is about 65C. I got the pipe from B&Q think it says 'QUAL P-EX' on it and says it's good for 92C. The fittings are JG Speedfit. It's clipped to the wall with the white, plastic, single screw, C clips. I'm fairly sure it's nothing to worry about, but it did suprise me.
| Top |
register or
log in
thescruff
Posted: Sun Nov 27, 2011 10:06 am |
| OAP |
I'm surprised it drapes at that temperature.
Should be ok provided it doesn't kink where it's fixed.
Sounds like you have a cheap own brand.
| Top |
register or
log in
Cookie
Posted: Sun Nov 27, 2011 10:15 am |
I think so too, gonna put a few extra clips in just to be sure.
| Top |
register or
log in
Cookie
Posted: Mon Nov 28, 2011 10:41 am |
I added a few more clips, but still not happy with the way this pipe is flexing, I think I am going to get some speedfit pipe and have another go at it. Unless someone can tell me this is normal. Here's a cold and hot pic Hot Cold
| Top |
register or
log in
thescruff
Posted: Mon Nov 28, 2011 10:45 am |
| OAP |
Probably normal, it don't look too bad now. Strange it straightens up when it goes cold
| Top |
register or
log in
register or
log in
thescruff
Posted: Mon Nov 28, 2011 2:10 pm |
| OAP |
Yes Mooncat, shouldn't be a problem
| Top |
register or
log in
Cookie
Posted: Mon Nov 28, 2011 3:06 pm |
Mooncat wrote: Should Pex tube be used like that? Is there a problem with it? Should I be using something else for hot water?
| Top |
register or
log in
OchAye
Posted: Mon Nov 28, 2011 6:26 pm |
| Senior Member |
Joined: Thu Apr 14, 2011 7:33 pm Posts: 479 Location: Dundee, Scotland. Has thanked: 43 times Been thanked: 43 times
thescruff wrote: Probably normal, it don't look too bad now. Strange it straightens up when it goes cold  It expands when hot and is it gets longer squeezes out between the clips?
| Top |
register or
log in
aeromech3
Posted: Mon Nov 28, 2011 7:05 pm |
| Senior Member |
Joined: Fri Feb 26, 2010 11:16 am Posts: 491 Location: Camberley Surrey Has thanked: 25 times Been thanked: 71 times
Thought the coefficient of expansion for copper was high but as that looked so ridiculous, I looked it up and for plastics it can be 4X more!  more reason to use copper.
| Top |
register or
log in
BillyGoat
Posted: Mon Nov 28, 2011 7:16 pm |
| Troll Headbutter |
Joined: Sat Jan 01, 2011 8:20 pm Posts: 1886 Has thanked: 77 times Been thanked: 130 times
There is a time and place to use each material, plastic isn't all bad!
Plastic can have a reduced cost of installation as you don't need special tools (soldering, pipe benders, etc) and quite frankly, is simple to DIY.
There are also occasions where plastic is a sensible choice - like my bathroom and some parts of my stupid shaped house. To install copper would have took the best part of a week just for a shower, bath and sink (5 walls, above three different rooms and not much in the way of access to joints/bends - plastic was super easy to work with and does exactly the same job.
I'm certainly not going to lose any sleep over unseen runs.
BG
| Top |
register or
log in
OchAye
Posted: Mon Nov 28, 2011 10:56 pm |
| Senior Member |
aeromech3 wrote: Thought the coefficient of expansion for copper was high but as that looked so ridiculous, I looked it up and for plastics it can be 4X more!  more reason to use copper. The only think I could think of was aluminium railings and railway tracks. It is the way that the pipe goes up and down between the clips that gives it away. When I started reading the thread I thought it will be getting hot and "melting" so it should go lower between every clip. To the OP. Using more clips to force the pipe to remain straight will exert more pressure at each end of it (assuming it can slide in the clips)... or it will produce a bigger curve where it finds the weakest clip.
| Top |
register or
log in
Mehran2
Posted: Mon Nov 28, 2011 11:21 pm |
| Senior Member |
Joined: Sun May 17, 2009 2:13 pm Posts: 515 Location: Hartlepool Has thanked: 4 times Been thanked: 33 times
making plastic pipe look neat for show is an a total pain in the arse. the best way I have found is allow slack in the bends..ie the expansion is taken up in the corners where it turns 90 degrees. also loads and loads of pipe clips every 300mm like this is your best bet: Attachment:
| Top |
register or
log in
