It is currently Fri Jan 18, 2019 1:28 am
PostPosted: Sat Feb 03, 2018 12:43 am
Has thanked: 15 times
Been thanked: 6 times
I was looking for some ogee to match existing and came across "Timber Architrave Ogee Best Pattern 52 25mm x 63mm (Finished Size) 20mm x 57mm". Does this mean when I put a measure against it I'll see 20mm and 57mm? If so, why mention the first set of dimensions??
It always takes longer than I thought
PostPosted: Sat Feb 03, 2018 12:56 am
Has thanked: 697 times
Been thanked: 2014 times
52x25 is prefinnished inch stock size so about minus 6 and 3mm or less [45x21mm]
PostPosted: Sat Feb 03, 2018 1:15 am
Ah, so "25mm x 63mm (Finished Size) 20mm x 57mm" means they took a 1" x 2½" stick and carved it down to 20mm x 57mm. Begs the question: why do I need to know what they started with?
PostPosted: Sat Feb 03, 2018 1:33 am
because historically the datum point is what its made from as in pre worked stock size
you need a datum point a uniform point to measure from to keep things the same
if you dont work to the same measurements or standards you cannot compare like for like
PostPosted: Sat Feb 03, 2018 11:49 am
Has thanked: 1187 times
Been thanked: 1080 times
By making both the real and "stock" sizes clear it saves any confusion. :?
