Ultimate Handyman Home
Patch a plastic soil pipe?
Post new topic   Reply to topic   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum
twistzilla
Junior Member
PostPosted: Sat Sep 13, 2008 10:41 am    Post subject: Patch a plastic soil pipe? Add User to Ignore List Reply with quote
Hello
We're removing the boxing in around a plasic soil pipe in a downstairs bathroom and found that the box has been nailed to the soil pipe. The nail is very close to the celing so I would have to take down my celing to replace a section of pipe.
Its only a very thin nail and it doesnt seem to be leaking - I was hoping to pull it out and patch it with something.
Can anbody give me some advice on how to make a permenant repair?
Thanks!
~Brett
Back to top
thescruff
PostPosted: Sat Sep 13, 2008 11:50 am    Post subject: Add User to Ignore List Reply with quote
If you have a piece of soil pipe lying around, cut a small piece, about 50mm round, clean it and the pipe and solvent weld the two together.
Scruff
Back to top
twistzilla
Junior Member
PostPosted: Sat Sep 13, 2008 11:59 am    Post subject: Add User to Ignore List Reply with quote
I'll need to go and buy the glue is it just called "solvent weld"?
Back to top
thescruff
PostPosted: Sat Sep 13, 2008 12:03 pm    Post subject: Add User to Ignore List Reply with quote
Yes it's called solvent weld, you will only need a small pot.
PUt plenty on both surfaces, and hold it on for a couple of minutes
Scruff
Back to top
Enliven
Junior Member
PostPosted: Sat Sep 13, 2008 1:13 pm    Post subject: Add User to Ignore List Reply with quote
Could you not use a gap filling cement instead of solvent welding a new piece of soil?
You can get it off Trading Depot but it also comes in grey so best to check in a plumbers merchants instead of buying online. I know City plumbing carry it.
I tried adding the url to this post but it won't display any of the text scratch
Back to top
thescruff
PostPosted: Sat Sep 13, 2008 1:20 pm    Post subject: Add User to Ignore List Reply with quote
Interesting post Enliven Laughing don't know whats gone wrong but you can't see it cussing
Yes, you could build a patch with gap cement, the pipe would need to be clean and dry.
Edit, your post is visible now Bang Head
Scruff
Back to top
twistzilla
Junior Member
PostPosted: Mon Sep 15, 2008 11:19 am    Post subject: Add User to Ignore List Reply with quote
Thanks Guys
I ended up buying some solvent cement and making a patch from a cheap piece of soil pipe from B&Q.
Its holding well so far, thanks so much for your help!
~Brett
Back to top
Display posts from previous:
Post new topic   Reply to topic    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum All times are GMT
Page 1 of 1
