-> Painting & Decorating Forum |
| Author |
Message |
bodgitandscarper Junior Member
Posted: Fri Nov 07, 2008 10:23 pm Post subject: Papering over emulsioned walls |
Hi All,
Back with another potential decorating problem. It concerns papering a skimmed wall that has being emulsioned, it was painted about 5 years ago is in good condition ie no flaking, do you need to prime it in any way or can you go straight over the top with paper, as always would welcome your comments.... |
| Back to top |
paintycait Senior Member
Posted: Fri Nov 07, 2008 11:27 pm Post subject: |
you can paper over the wall no bother. You may want to line the wall depending on the budget and quality of paper. _________________ www.decoratescotland.com |
| Back to top |
Welsh Decorator Senior Member
Posted: Sat Nov 08, 2008 4:44 pm Post subject: |
It should pose little or no problem, but for a 'belt and braces' approach, the best place to start would be to prime or seal the existing paint, either with a plaster primer, dilute oil based undercoat, alkali resisting primer or any of the other proprietory products out there, Zinsser has a couple.
By doing it this way, you are ensured of a good background to work from, and will have no trouble with eadges springing or paint blistering due to paste wetting it.
As painty has pointed out, it's down to budget and time you want to spend. _________________ I'm not a roman mum, I'm a kike, a yid, a heebie, a hook-nose, I'm kosher mum, I'm a Red Sea pedestrian, and proud of it! |
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You can attach files in this forum You can download files in this forum
