Ultimate Handyman Home
paint in recently skimmed room
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plastering Forum
danm123
Junior Member
PostPosted: Fri Aug 24, 2007 7:39 pm    Post subject: paint in recently skimmed room Add User to Ignore List Reply with quote
Had a room skimmed recently and on the advise of the bloke in B&Q, gave it a coat in some cheap emulsion to seal, before i get round to the painting
a small patch of the wall has gone yellow, like a waterstain
the only time i have seen this before was when a plumber spilt a load of water in the loft and i came through and discolored the ceiling angry
question: Can fresh plaster, if not properly dry disclor paint in this way.....the patch in on an inside wall, half way up the wall so im at a loss where any water could have come from to just affect that one point. scratch
cheers..
(i'm gonna double this post up on the plastering forum in case someone sees it there....helpful to get a quick reply so i can sort any problem out tomorrow)
Back to top
PostPosted: Fri Aug 24, 2007 7:56 pm    Post subject: Add User to Ignore List Reply with quote
Sealing the plaster with diluted emulsion is ok, but you may of applied it before the plaster was dry enough. A better choice instead of emulsion would of been Dulux trade supermatt as described here-
http://www.ultimatehandyman.co.uk/when_to_paint_new_plaster.htm
DIY | DIY Video
Back to top
danm123
Junior Member
PostPosted: Fri Aug 24, 2007 7:59 pm    Post subject: Add User to Ignore List Reply with quote
thanks mate - so if not properly dry, then this would be a potential side effect as the water comes out the plaster???
i'm more concerned with ruling this out than having sprun a leak somewhere that i can't see and to the best of my knowledge have no pipe Shocked
Back to top
PostPosted: Fri Aug 24, 2007 8:03 pm    Post subject: Add User to Ignore List Reply with quote
Where exactly on the wall is the stain?
Is it at the top near the ceiling or is it a few feet from the top or bottom?
DIY | DIY Video
Back to top
danm123
Junior Member
PostPosted: Fri Aug 24, 2007 8:24 pm    Post subject: Add User to Ignore List Reply with quote
2/3 foot from bottom
Back to top
PostPosted: Fri Aug 24, 2007 8:47 pm    Post subject: Add User to Ignore List Reply with quote
It's unlikely that it has been caused by a leak then IMHO
Perhaps it has been caused by some of the salts in the plaster?
DIY | DIY Video
Back to top
LUFC
PostPosted: Fri Aug 24, 2007 9:41 pm    Post subject: Add User to Ignore List Reply with quote
is the wall where it is occuring an outside wall. it could be damp coming throught the wall.
Back to top
andy-p-
pro plasterer
PostPosted: Sat Aug 25, 2007 6:19 am    Post subject: Add User to Ignore List Reply with quote
What room is it in, ie - is it below the bathroom, have you got soild walls (sand & cement or hardwall) or plasterboard walls and as lufc said is it an external wall? What was it like before the reskim?
Back to top
danm123
Junior Member
PostPosted: Sat Aug 25, 2007 10:38 am    Post subject: Add User to Ignore List Reply with quote
wall is internal, solid brick wall.
All was fine before the skim
Back to top
andy-p-
pro plasterer
PostPosted: Mon Aug 27, 2007 7:07 am    Post subject: Add User to Ignore List Reply with quote
scratch
Best thing is to ask the plasterer to come back and have a look, see what he says
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plastering Forum All times are GMT
Page 1 of 1
