Page 1 of 1
[ 6 posts ] |
| Author |
Message |
DNS
Posted: Thu Apr 21, 2011 1:36 am |
| Senior Member |
Joined: Thu Oct 07, 2010 5:21 pm Posts: 160 Has thanked: 16 times Been thanked: 5 times
Might well be a stupid topic... but...
What are professional trowels made of?
I've got a budget one which I started with and is now rusted as hell, as well as a mid-range one which is now pretty rusty too (for about 3 days I dried it and oiled it after use, but then couldn't be bothered!)
Is it normal for a trowel to have surface rust? Doesn't seem to affect the way it works at all, seeing as the edges are still clean.
Are professional plasterers trowels made out of stainless steel or some other non-rusting metal, or is rust just something which everyone lives with?
| Top |
northy 93
Posted: Thu Apr 21, 2011 5:01 pm |
| Newly registered Member |
Joined: Sat Dec 04, 2010 2:10 pm Posts: 9 Has thanked: 0 times Been thanked: 2 times
my trowels are all stainless steels so dont get the rust but wen i did have a steel trowel use to have a rag and wd40 to protect it over night but im a plasterer buy trade so was using it every day to keep on top off it
| Top |
register or
log in
jozeffo
Posted: Fri Apr 22, 2011 7:12 pm |
| Senior Member |
Joined: Tue Dec 02, 2008 7:52 pm Posts: 2448 Location: South London Has thanked: 58 times Been thanked: 272 times
Ragni trowels are fine and they rust because they are not stainless. Marshalltown dont rust and are stainless. I have one of each plus a few specials.
Marshalltown cost about forty quid and ragni about twelve. If you look after the Ragni. it should outlast the stainless ones because the steel is stronger, at least in theory.
| Top |
register or
log in
royaloakcarpentry
Posted: Fri Apr 22, 2011 10:49 pm |
| Senior Member |
Joined: Sun Jan 24, 2010 1:48 pm Posts: 4152 Location: Essex Has thanked: 2 times Been thanked: 327 times
Mine is marshalltown and gets a quick rub down with glass paper before each use.
| Top |
register or
log in
Crooksey
Posted: Mon Apr 25, 2011 7:14 am |
| Senior Member |
Joined: Sun Jan 03, 2010 3:16 pm Posts: 303 Has thanked: 0 times Been thanked: 26 times
All my trowels, brick, mortar, pointing and skimming trowels are Marshalton and look as good as they day I bought them.
I have ragini, corner, bucket, small and pipe trowels. And they all look rubbish after 12 months!!
_________________ My project blog - Check it out
| Top |
register or
log in
dextrous
Posted: Mon Apr 25, 2011 9:13 am |
| Senior Member |
Joined: Tue Dec 21, 2010 11:26 pm Posts: 230 Has thanked: 42 times Been thanked: 16 times
Invested in a Mashalltown preworn stainless steel one. Haven't used it for a couple of years but it's spotless and rustless and lying in the garage. To remove some long-standing crusted on plaster, I left it in a bucket of water before scraping the eggshell layer (along centre of the underside) with no problems whatsoever.
| Top |
register or
log in
Page 1 of 1
[ 6 posts ] |
