It is currently Fri May 25, 2012 7:27 am
PostPosted: Mon Nov 21, 2011 10:01 pm
I turned on top light on ground floor and it went out. thought the circuit breaker tripped but it hadn't. discovered the top light closest to the circuit breaker works but none of the others on the circuit will come on. (light by front door, bathroom, kitchen, hallway, dining room).
Is it possible for one light fitting to go bad and stop the ones that follow in the circuit from working? similar to the way lights on a christmas tree stop working.
steve
PostPosted: Mon Nov 21, 2011 10:14 pm
Has thanked: 134 times
Been thanked: 472 times
heeelllooo and welcome sdechant :welcome: :welcome: :welcome:
sort off
the power is reaching the first light but not number 2 in the circuit so the fault is likely to be a bad connection or broken wire between light one and light 2 in the circuit
so with the power off check the connections at each light fitting
has there been any work done in the area off the lights or connecting cable or indeed anything unusual happened since the last time the lights worked
PostPosted: Mon Nov 21, 2011 10:34 pm
No work been done or anything unusual. I have a feeling that the outside light which is very old has just given up the ghost. will check it tomorrow. thanks and i will definitely keep an eye on this site.
